What will it run? 00 SS LQ9 LS3 Heads
Trying to see what a realistic goal is for this new setup I put together.
Build details:
LQ9
823 Heads
Ls3 intake/Injectors
90MM TB
TSP Stage 4 cam 235/239 .627"/.624" 112LSA
Circle D 5C 4k RPM Stall
3.42 Gear
1 3/4" Hooker LT
Magnaflow C/B
SLP Air lid
Fast Toys Ram Air
Tuned by Me
Full Weight
Minimal suspension work
Hoosier 26" slick
I took the car for a shake down run this past weekend and it went 11.61@116.6 on a 1.59 60'. I was still working on the tune but the weather was too good to pass up. Car was super lean at WOT but I didn't pickup any KR(14:1 AFR at WOT).
I have the tune squared away now. 12.8:1 AFR at WOT and am looking to see what others think it will run now? Ultimately, I think the car will go 11.2x @ 118. I have skinnies I can throw on the car and sub frame connectors to put on as well.
Build details:
LQ9
823 Heads
90MM TB
3.42 Gear
1 3/4" Hooker LT
Magnaflow C/B
SLP Air lid
Fast Toys Ram Air
Tuned by Me
Full Weight
Hoosier 26" slick
Stock heads. Based on hptuners "delivered engine torque" the car picked up 60-70 lb ft of torque at 12.8 AFR WOT compared to 14.0 AFR. Also cylinder air mass bumped up from the low .8 g/s to low .9 g/s(most likely just because I calibrated the MAF for the new setup) which moved my spark reference a littler so I'm at a degree or 2 more advanced timing now(27.5-28* at WOT).
I dunno man, I'm guessing with the extra torque..he may see a bit of an ET improvement...but not so much with the trap. Torque is what gets the car going.....horsepower "carries" the car. Just thinking out loud.
Finally got to the track tonight. Car went 11.43 on a 1.52 60'. Still no SFC's or skinnies on the car. Car also went 11.44,.45,.46.48 all on high 1.5x 60' the rest of the night. I need to figure out the suspension because the car always does a one hop on the launch.
