Welp, busted rear end is my "track result"
It finally bit me. After years of driving to the track on factory rear ends.....I was nearly stranded. First pass of the evening, I popped a worm gear in the posi. As I coasted down the track, all I could think about was what the wrecker bill would be being about 2 hours from the house. Fortunately for me, I was able to limp it home. Just picked up a new carrier for cheap, with some 2:73s. Will definitely be purchasing a real rear end next year!
You might be ok. I think this one was weakened after a 3rd to 2nd mis shift a few months ago. I killed the rear end before this one the same way. I think this time it was just delayed. And if your truck is automatic, you may enjoy many passes with it.
Yea, it was always in the back of my mind. Funny thing is, both times the ring and pinion have come out unscathed. The actual gears are not the weak point.....it's the worm gears in the posi unit. And truth be told, this one would probably still be alive if I hadn't did the ole 3rd to 2nd stunt. Now, you on the other hand may have the opposite problem...as you have 4:10s. Tall gears are usually able to stand up to more abuse. Hopefully you get by at your track day, just don't get greedy and give all of it out the hole
Tru Trac might last a bit longer, but after I install this next carrier.....I'm not spending another dime on this 10 bolt. Next rear I put in is going to be a "from now on" unit.
I understand that you don't believe the car makes what I say it does, and that's cool.....I guess the dyno wad rigged and or I lied.....even though I filmed the car on the dyno. We will also ignore the gearing as well.
