Slightly better results
Old 02-06-2017, 08:30 PM
zzracer's Avatar
Default Slightly better results
Went to the track 2-5-17 to try out my 3.73 gears. I was hoping for more of a gain from the gears since I have ran 6.76 with 3.08 gears. The car is leaving harder but it's seperating more now. I think I'll add some travel limiters and start tuning the strutts from there.
It was running consistent low 1.5 60s barely lifting the drivers wheel after I added an anti roll bar. Now it's lifting both wheels and ran a best 60 of 1.44 .
Old 02-06-2017, 08:33 PM
zzracer's Avatar
This is the best picture of the launch. I think if I can calm it down I may can get low 1.4 to high 1.3 60 on a good pass.
Old 02-13-2017, 11:32 AM
SoFla01SSLookinstok's Avatar
Looking good! I agree with your thoughts. Start to fine tune. She's working!
Old 02-13-2017, 11:45 PM
zzracer's Avatar
Thanks!
We got to looking over my time slips and comparing them to my previous best with the 3.08 gears and I gain in the 60 and 330 and fell off after that. Checked the runs out that I logged and found out I am losing time on the 2-3 shift even though we made some passes to dial the shift points in 3rd is still lazy. May be time to go through Transmission now. Thought I would gain more from the gears and I may once everything is ironed out.
Old 02-14-2017, 03:07 PM
Originally Posted by zzracer
Thanks!
Yea, that does sound a little odd. Are you happy with how it's going through the 1/4 trap according to rpm?
Old 02-14-2017, 07:01 PM
zzracer's Avatar
I haven't ran the 1/4 since the gear change. With the 3.08s it was changing to 3rd to close the the beams to take advantage of 3rd gear and I tried running it on out in 2nd in the 1/4 and it didn't like that either. The 2-3 shift could have been part of the problem on the 1/4 passes too .
Old 02-14-2017, 07:07 PM
Ahhh. Once you get it all ironed out it'll be cool to see what it does.
Old 02-14-2017, 07:17 PM
zzracer's Avatar
When I started this build my goal was 6.50s with a sbe ls2 N/A and drive to and from the track .
Old 03-05-2017, 05:58 PM
madmike9396's Avatar
Man you really got that 5.3 hauling some ***. Great job
Old 03-19-2017, 09:08 PM
zzracer's Avatar
Default Done a little better today
Done a little better today. I was in the right lane.
Old 03-22-2017, 11:10 AM
if I didn't know any better id swear you were spraying that 5.3
Old 03-23-2017, 07:06 PM
zzracer's Avatar
5.3 LOL, That would be doing something. You might as well think I am spraying because everyone else does.
Old 03-24-2017, 02:02 PM
I know better. different stall and some spray and you would probably hit 5s
Old 03-26-2017, 09:39 AM
It's a 6.0.
Old 03-27-2017, 06:52 AM
zzracer's Avatar
Originally Posted by SoFla01SSLookinstok
It's a 6.0.
Sure is . Stock bottom end LS2!
Old 04-10-2017, 08:40 PM
zzracer's Avatar
Default Ran a little better 4-8-17
Ran a little better Saturday 4-8-17.
Ran 6.60 ,best pass to date.
Old 04-11-2017, 08:59 AM
z28241's Avatar
Dude that 60'! car is roliing out!
Old 04-12-2017, 07:00 AM
zzracer's Avatar
I am hoping with a few more tweaks I can run some 1.3? 60s and run low 6.50s.
Old 04-13-2017, 02:07 PM
Mike Morris's Avatar
Great job!
Old 04-14-2017, 03:55 PM
HioSSilver's Avatar
Nice job chippin away at it
Quick Reply: Slightly better results
