very serious guys!??!?!?!?!!?!?
Old 01-03-2005, 04:38 PM
prostock_bigblock's Avatar
Default very serious guys!??!?!?!?!!?!?
Hi guys,
i dont want to take u guys in a very long discussion but in a very shortwords , what is the best time could a ls1 get in 1\4 mile ? could someone list me a 6 or 7 second times?????plzzzz if there are? is it worth it to work on a ls1 ? or should i look for a big chevy,,,,,,,,
thank`s alot
Old 01-03-2005, 05:29 PM
SMOKIN01TA's Avatar
if you want 6's you better look into a bigblock. ls1's havent advanced that far quite yet, they are just getting to where they can probably go 7's. give it af few years though and id say yea, we are progressing very quickly
unless ofcourse your thinking of puting it on a dragster than a 7 is easy.
Old 01-03-2005, 06:07 PM
bad2000ss's Avatar
You would be hard pressed to get a big block chevy into the 6's let alone an LS1. Perhaps a 700+ cubic inch big block with a ton of nitrous. It certainly wouldn't be a car in any kind of street trim and it sure as **** wouldn't be cheap.
In a 3000lb car you would need a minimum of 1200 horsepower to the tires to make 7's then add at least another 500 horsepower to dip into the 6's. A big block chevy would be a better platform to start with but you'll be spending a ton of money either way.
The other option would be to build yourself a 2000lb door stop on wheels, drop in a turbo/supercharged 420somethin cubic inch LS1 making about 1200hp to the tires and you might get sixes.
If this is a serious question, I hope you've done a lot more research on the subject other than one post on an internet board.
Old 01-03-2005, 08:32 PM
B18B1LS1's Avatar
It's going to take alot more than 1200 rwhp to run in the 6's. Maybe double that number with a light car, then it's doable. Unless were talking tube chassis or rail.
Old 01-04-2005, 12:07 AM
i would like to thankyou guys for getting your attention and also for the quick honest answers my point was having some of your knowledge about were can i go with my ls1.
thank`s again
Old 01-04-2005, 02:48 AM
Abdullah's Avatar
i think you can go with your LS1 as fast as low 8's@165-170 mph harlan has a twin turbocharged LS1 TA and he went i guess 8.22@167 mph.
Old 01-04-2005, 01:03 PM
wickedwarlock's Avatar
I'll be they will be hitting those 7 marks this year. I think there's an lt1 running 8.35s here too. They are not far off for sure.
Good luck with trying to get something into the 6s. $$$$$$$$
Old 01-04-2005, 08:01 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
yep, definately cost you more dinero to run 7s (or pipe-dreaming of 6s) with an LS1-based motor than the tried-and-true SBC/BBC methods.
Derek
Old 01-04-2005, 08:47 PM
Lafngas98Z's Avatar
Give it a little more time 6's WILL happen. Probably not stock suspension but they will come. I am pretty sure LS1's could run 6's right now in the right car. Picture this: A C5R motor in a tube chassis car with a heathy shot of nitrous. I say nitrous because that is what the car I have in mind will be using, but boost would get you there as well. OOps cats out of the bag.
Old 01-04-2005, 09:18 PM
NLang's Avatar
You'll just have to give the chassis/body just as much attention as the engine.There's a BIG difference between a 3400lb car and a 2400lb car. BIG difference...
Old 01-04-2005, 10:32 PM
A3Z28's Avatar
6.90s in the 1/4 with a big block chevy NA isn't hard to do, if you have the budget, look at the pro stock class, they're going 6.65ish at 207+ with NA 500 CI big blocks, not bad, but they are a tube chasis launching at 5000+rpm also...
Old 01-04-2005, 11:03 PM
blubird's Avatar
I think 7's w/ ls1 based motor is definately possible. 6's are difficult with about anything. A 400"+ motor and 90mm+ turbo and 7's are just a descent chasis away. Slap a big 106mm on it and a 2600# car and you might get a six.
Old 01-07-2005, 11:06 AM
MARKSZ71's Avatar
we got a full bodied 67 chevelle that runs 820s with a 540 and 250shot nitrous it takes a lot to go fast
Old 01-07-2005, 10:43 PM
A3Z28's Avatar
it takes less than most people think to go fast....common sense and patience are the two most important things....well those and $$ but i've gone pretty fast before with a relatively small investment.
Quick Reply: very serious guys!??!?!?!?!!?!?
