heads and cam times!!
well just got in from first time out at the track with the car since the new combo. I am having trouble with my shifting, but the power is deffinately there.
tsp 233/239 cam
prc stage 2.5s
tsp mail order tune
1st run
12.4@118
2nd run...
12.17@122
3rd run
12.14@123
again having trouble shifting every run...am going to flush clutch system tomorrow and do the drill mod, only started having problems since the rev limiter was raised(6800).. never tried runnning N20..want to get shifting issues worked out first.
tsp 233/239 cam
prc stage 2.5s
tsp mail order tune
1st run
12.4@118
2nd run...
12.17@122
3rd run
12.14@123
Originally Posted by 30th t/a
thats awesome mph. whats your car weigh? did you have skinnies up front?
the car is full factory weight, I believe like 3750 with me in it, I am running factory size tires front and rear also. thanks
Congrats on the MPH.
You said it wasn't the tires?? 1.79 60' with that power isn't right. You really need to get a better set of tires. What rpm's are you launching at?? With 122mph you should be running mid to low 11's. Get the clutch issue resolved ASAP. No reason to hurt anything else.
Good luck
David
Good luck
David
the reason thbat I am happy with the 60fts is that I am still on a stock rear. I know with the power it could be way better, but I am happy with them for now. By the way got the clutch issues worked out. I removed the master cylinder and did the drill mod and also flushed the sytem while I was in there. Put new fluid in and bled the slave....Wow what a difference I can shift like crazy now at any rpm, also shifts much better just driving regular..So I should get back to the track this week to get a full pass in on the motor and a juiced run...will let you all know..by the way all of those runs were on motor only.
Originally Posted by Got Me SOM
who is PRC? seems to be a strong package you have there. I'd get a 12 bolt real fast, its only a matter of time before that rear lets go.
LS1Tech Premium Sponsor
Thats awesome mph man! Sounds like that setup is running great We've been selling alot of those heads recently & everyone seems to be very happy with them
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
got some bad news!
