11.97@116.39 need some input
This time was with TNT F1 100jets, 4.56 gears in factory 10 bolt, Hooker LTs, Exhaust Cutouts. Is this a good time?
r/t .590
60' 1.864
330 5.125
1/8 7.757
mph 94.65
1000 9.981
1/4 11.974
mph 116.39
r/t .590
60' 1.864
330 5.125
1/8 7.757
mph 94.65
1000 9.981
1/4 11.974
mph 116.39
Originally Posted by Coach 02 A3 Z/28
Seems slow to me. What type of tires are you running?
Coach
Coach
LS Won, is something happening with the spray in the second half of the 1/4? What pressure are you keepin the bottle at to start with? I always keep mine between 1100 and 1200 before goin up to race. I've found 1150 seems to be the sweet spot! Was the bottle full, or were you runnin on empty (maybe it started to run out toward the end)?
Originally Posted by Loudmouth LS1
Hey coach, is it just me or does it seem like his mph is dyin off from the 1/8th to the 1/4? I know i've trapped high 92's - low 93's in the 1/8th on motor and that equated out to high 116's - low 117's in the 1/4. He's at almost 95 mph in the 1/8th, I would think he should be in the 118 - 119 range in the 1/4.
Originally Posted by blubird
No cam. He's probably out of gear before hitting the traps with those 4.56's.
im new to n2o this was my first experience with nitrous, my bottle pressure was 850-900 i think. im gettin the car tuned pretty soon. and im running mickey thompson et street radials 275/40/17's (i couldn't get those tires to hook at all) and i switched on the nitrous in second gear. last year i ran a 12.77@108.18 pre gears/clutch/n2o/ported tb/maf/removed !air !egr, AC/exhaust cutouts
