How about a 1/8 mile to 1/4 mile calc sticky?
Old Drag Racer
Unfortunately there's no one single conversion factor that works with all cars. My SS works out to 1.575 but it's because it 60's well so it ET's well in the 1/8th. 1.59-->7.66@88.5-->12.07@111.82 in my case. Other cars with much more horsepower but street tires may run similar times in the 1/8th compared to my car but will be much quicker by the 1320' mark. Most cars that don't have wheelspin factor between 1.55 and 1.58 but there will always be those outside this window. Hope this helps you with us 1/8th milers.
The pass I've made with set of street radials...
1/8 = 7.453@99.30
1/4 = 11.398@126.36
Using 1.57 factor to calculate 1/8 time to 1/4 time.
7.453 x 1.57 = 11.701
So, that is .303 difference, bit more than close, imo.
1/8 = 7.453@99.30
1/4 = 11.398@126.36
Old Drag Racer
1/8 = 7.453@99.30
1/4 = 11.398@126.36
1/8 = 7.453@99.30
1/4 = 11.398@126.36
Originally Posted by Smokinstorm
Your car with street tires will fall outside the 1.55-1.58 window because you ran a truly crappy 1/8th mile time compared to your MPH.
It wasn't good but not crappy. On that pass, I cut 1.820 60' time but yeah, I had lot of spin all the way to 3rd gear. I understand what you are getting at though.
gator's 99TA
Yes. Normally, I spray right after 2nd gear but on that pass, I did spray right after the launch.
This one has worked out pretty close for me. http://www.wallaceracing.com/eigth-t...conversion.php
More calculators http://www.wallaceracing.com/Calculators.htm
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
I think conversions have a lot of gray area, and every car is different depending on set-up, even if you are dead-hooking.
For example on my Nova:
7.221 @ 93.79 mph 1/8 mile x 1.57 = 11.33
7.221 @ 93.79 mph 1/8 mile x 1.575 = 11.37
7.221 @ 93.79 mph 1/8 mile x 1.58 = 11.409 (closest to the 11.42 I actually ran).
Versus my Formula:
8.325 @ 85.80 mph 1/8 mile x 1.58 = 13.15
8.325 @ 85.80 mph 1/8 mile x 1.57 = 13.07
8.325 @ 85.80 mph 1/8 mile x 1.56 = 12.98
8.325 @ 85.80 mph 1/8 mile x 1.55 = 12.90 (closest to the 12.89 I actually ran).
Remember, it's just a guess and gives you what COULD BE your 1/4 time.
Derek
Versus my Formula:
Derek
