Whats wrong here?
Whats wrong here?
Went to Lapeer today to try and get a new p/b with the new cam and all. If you guys want to check out all my mods they are in my sig and this is the best I ran.
60' 2.136
1/4 ET 12.860
1/4 MPH 111.83
Obiviously I'm very pissed especially since my old LPE GT2-3 cam trapped 114 and ran 12.55 on a similar 60'. Anyone know what may possibly be wrong?
60' 2.136
1/4 ET 12.860
1/4 MPH 111.83
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
A 2.13 60 foot time is a lot of the et there, especially with a good converter. What kind of tires are you running?
As mentioned above, the weather right now in summer time will affect 2-3 tenths compared to cooler fall/winter weather.
Derek
Derek
DA is usually low here in Michigan and yesterday was mid 70s with a slight breeze it seemed like perfect weather. I realize my 60' is affecting a lot of the ET but with my old smaller cam and the same 60' I ran 3 tenths faster and 3mph more. I'm only running shitty worn 245 Nittos which are done now so I will be ordering Mickey Ts soon. After talking with my tuner it seems to be either injector overduty or a clogged filter since my 1/8 mile is strong.
The numbers are in my sig. The guy that tuned my car always dyno'd it unlocked though. With the old LPE cam it put down 345rwhp on his dyno and after the MS3 it put down 362rwhp it should make around 400 locked on a dynojet since before the tune it put down 380 with the converter locked.
OK well I don't know why everyone here is against Fuddle converters but I have never had any problems with mine aside from the fact that it eats up hp on the dyno but all converters do. It stalls to 3100 rpms and always flashes to 3600 or higher, I was planning on sending it to get restalled to 4000 this winter as to not have downtime. The car is always run exactly as it is on the street, full weight with DRs. The gears are stock 3.23s which will stay until I buy a 12 bolt then I will go 3.55 or 3.73 since I still want to DD it when its nice out.
Beg, borrow, steal, whatever some 16x8 stockers with 255 50 R16 M/T radials...You car is making similar power to mine and those M/Ts work great with A4s...I went 1.55 60's all day long with those things last year...I have a Vig 3600 and launch off idle...A 1.55 for you would be an 11 second run, if not real close to one...There's .5-.6 in your 60' alone...Good luck..
--Alan
--Alan
Originally Posted by Villain281H
what was the 1/8 mile time?
regardless, your power is down for the mods you have. hell i trapped 110 with a 2.1 60' with bolt-ons and a 3,750lb raceweight. ~2,500' da.
have you done a compression and/or leakdown test since the heads/cam? what did the car run prior to the mods?
