The "Heavy List"
The "Heavy List"
If your pig flies, list it here. Rules are as follows. Min Race Weight is 3500lbs and LSX or LTX powered. No other rules. One list for NA and one for PA.
When posting for the list, please keep below format so I can just copy and paste. I will not add it unless you have had the car on the scale and know the weight.
..: Naturally Aspirated :..
Board ID - 1/4 ET @ MPH (60ft), Yr & Type of car, Trans, Converter/Clutch, Gear, motor, Cubes, Cam, Heads,
DA, Race Weight, Date
1. N20Dave, 9.98 @ 137 (1.47), 1995 Z28, G-force 5speed, 4.30, 396ci LT1, SR, SB2.2 heads, 800', 3730, 3/15/08
2. Choppin-Suey --- 10.38 @ 130 (???), 2000 Z28, Th400 , 4,000 stall, ???, AFR, PSI cam, 3680 lbs, LS?, ???, ???
3. taner --- 10.54 @ 129.28 (1.45), 96 Camaro SS, T56, McLeod Street Twin, LT1, 398ci, ???, ???, ???, 3520 lbs, April 05
4. NosboySS --- 10.56 @131.9 (1.47) 98 Formula WS6 TH350 w/ 3800 stall, 3.73's, LS1, all bore 383, custom cam, ETP, ???, 3520lbs, 1/13/07
5. Michael4034---10.70@130.94(1.58)--01camaro---Spec Twin Disk--LS2 404--NA---3650lb---Nov. 23 2007.
6. Mike TexaSS --- 10.72 @ 128.75 (1.49) 1996 Impala SS, 200R4, ???, 4.10, LS1, 454, Custom Hyd, 6.0 ported, ???, 4300, ???
7. JL ws-6 10.80 @123,97, (1.53) 01 transam ws6, hughesTh400, Ultimate converter (5800), 4.10 gear, Ls2, 402, ET240 heads, Eastside stroker cam, 746, 3580 lbs, 10-27-06
8. SLP 02 SS----10.897 @ 123.10 MPH (1.47), 02 SS, A4-Level 5, SS4000, 3.70, LS1, 346, FMS/F-15 236/239, AFR 225's 61cc w/ 2.05/1.60 valves, ???, 3720, 02/10/07
9. NB99Z----10.96 @ 125.6 (1.55), 99 Z28, T56, Ram clutch, 9-inch 4:30's, LS1, 346, 23?/240, Ported Dart 225's,
-300, 3520, 11/4/06
10. FASTFATBOY - 11.02@124 mph (1.53), 94 Z28, 4L60E, 4200 converter, 4.11, LT1, 383 inches, Solid roller, RHS 235's, 3800lbs, 12-16-07
11. 7420NW7TH, 11.17 @ 123 (1.63), 1998 WS6, TH400, Yank pt4000 stall, 3.73, 408ci iron block, AFR 225 heads, 1100', 3800 LBS, 5/26/08
12. KCFormula 11.22@127.5 (1.7) '99 Formula T56 LS6 heads SR cam, 421ci @3780lbs NA
13. HumpinSS - 11.23 @ 122.40 (1.54), 2000 Camaro , M6, Ramn VDS 980 , 4.56, LS1, 346, G5X4, Stock,-515 , 3600 , 12/30
14. camarokid94 - 11.309@125.7 (1.72) o1 - camaro - 6M - centerforce DF 12in - 3.89 - 402 iron - 244-248 612-615 113+4 - AFR 205s - ?? - 3860 - mid 07
15. My 04 Goat - 11.43 @ 119 (1.55) 2004 GTO, M6, Carteck clutch,Stock 3.46, LS1, 382, Cartek 3X, Cartek 4X, (???), 3575, 12/1/07
..: Power Adder :..
Board ID - 1/4 ET @ MPH (60ft), Yr & Type of car, Trans, Converter/Clutch, Gear, Heads, Cam, motor, Cubes, Power Adder, amount,
1. TwnTrboCE --- 8.40 @ 168.56 (1.39), 2002 Trans Am, TH210, Midwest 3,800, 3.50, TEA Darts, Comp custom, ERL LS1, 387, Single 98 turbo, 28psi, ???, 3700lbs, 10/21/06
2. Shiz --- 8.91 @ 152 (???), 2000 Z28, Glide, ???, ???, AFR heads , PSI cam, LS?, 408, Nitrous, ???, ???, 3550lbs, ???
3. MIGHTYMOUSE - 9.05 @ 155.76(1.50), 98 WS6 TA, 4L80, Yank 3400, 3.42, AL LS2, 364, Turbo Cam, All Pro Heads, ?, 3870, 11/18/07
4. ATVracr--- 9.05 @ 149 (???) ... 99' Formula, Th400 , 4,000 stall, ???, ET heads , PSI cam, LS?, 368 cubes, Nitrous, 2 stage 225 shot ,??? , 3700lbs, ???
5. taner --- 9.08 @ 155.07mph, 1.425 60', 96 Camaro SS, T56, McLeod Street Twin, LT1 398ci, n2o, ???, ???, 3550 lbs, 10/6/06
6. NA$TY-TA - 9.26@150.58 (1.45 60ft), 98 TA, Glide, Neal Chance, 3.73 then (3.54 now), 6.0L, 224/222, Iron 6.0L, 370ci, 88mm Turbo, 20 psi,
DA, 3509#, 23July06
7. 1DirtyZ - 9.38@ 146 (1.39 -60ft- foot brake), 99 Camaro, Th-400, PI 3500, 3.43:1, 427 LS7, custom cam, TSP ported L98 heads, F1-r, ????, 3550 lbs, june 2007
8. BLK02WS6 --- 9.41 @ 143 (1.41 back tires), 02 Trans Am, TH400, Pheonix Pro 3800, 3.73, Hoops heads, TSP giant cam, LS1, 408, Nitrous, 250 shot, ???, 3685, 12/3/06
9. Lisa33 9.44 143 (1.38) 1995 Z28, 4l80e, 9.5vig, 3.42, 383LT1, Procharger F1, 60shot N2O, ported TFS from LE, Bret B cam
3630lbs 10/9-06
10. Caveman: 9.74 @ 138.48, 1.35 60'
1998 Formula / Century/WCR Racing 4L60, Yank PT 3800 / Stange 12bolt, 3.42s / LS6 resleeved 382 / Vortech Ttrim, 10psi / AFR 225s / Comp 230-236 114 lsa / 1200' DA / 3685 raceweight / 3-28-08 ,Orlando Speedworld
11. Choppin-Suey --- 9.86 @ 136 (???), 2000 Z28, Th400 , 4,000 stall, ???, AFR, PSI cam, LS?, ???, Nitrous, Dry 100, 3680, ???
12. N20stroker--- 9.95@135 (1.39) 2000 T/A, TH400, 4200 stall, 3.73, Patroit stahe 3 heads, 244/248 cam, LS?, 402, Nitrous, 150 wet nozzle, ???, 3790, 10/11/06
13. Ryan K - 9.989 @ 128.15 (1.494), 98 Camaro B4c, TH400, ATI MRT Custom, 3.50, AFR 225's, 224/224 Comp Cams Custom, 370, TTi single 82mm Turbo, 10 psi, 3000ft, 3700lbs, 9/15/07
14. TwoFast4Lv --- 10.05 @ 135.8 (1.49), 95 Camaro Z28, SSEFI A4, Yank 3,800, 3.73 12 Bolt,LT1, 380ci,SSEFI KILLER, LE-X, 900ft, 3660 lbs,Nitro Dave's 200hp DP, Oct 06
15. Nostang--10.20@133 (1.463) 96Z28, th400, 4500 nitrous verter, 3.70 gear, 28" ET street, Lt1 355 11.5-1, GTP s2 LT4 H/I, GTP-6 cam, Nx single fogger 200 shot, 3650 raceweight, 3900DA 07-13-05
-300, 3520, 11/4/06
..: Power Adder :..
DA, 3509#, 23July06
3630lbs 10/9-06
I was hessitant since you did not list an actual weight. Your on now but I would like to get a weight reading from a scale. I am sure it is 3600+ but I want to keep the list true to the rules.
