10.73 @ 130 Full Weight Ported Eaton Cobra with 75 shot....
Old 11-12-2007, 11:32 AM
Black03's Avatar
Default 10.73 @ 130 Full Weight Ported Eaton Cobra with 75 shot....
I know it's a ford, but I just thought I would share with fellow car enthusiast. Well after a long day of the "House of Hook" hooking too well and bogging ALL day long I finally got a clean run in. I tried launching higher and higher, then added pressure to the tires not wanting to drop the hammer too high. The car is full weight minus prostars, stock suspension, upper only ported eaton, wet 75 shot......
My best pass of the day on motor.....
Old 11-12-2007, 11:33 AM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Not too shabby for a full weight car
Derek
Old 11-12-2007, 12:39 PM
big dave's Avatar
that's getting it . Congrats. Have you weighed that beast. I know they are pretty heavy.
Old 11-12-2007, 12:41 PM
Bryan @ Speed Inc.'s Avatar
i don't really think you were ever on motor. lol.
good times! congrats.
Old 11-12-2007, 01:18 PM
Black03's Avatar
Well yeah I guess blower only.....
Old 11-12-2007, 01:23 PM
Black03's Avatar
It was around 3740 with me in it.
Old 11-12-2007, 02:50 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Nice numbers, stock rear?
Old 11-12-2007, 03:38 PM
Black03's Avatar
Yeah stock rear, I just cut the stock springs about 3/4 of a coil....
Old 11-12-2007, 08:54 PM
UnbelievabLS1's Avatar
you only pick up 2 mph on a 75 shot? Awesome times, but I would have thought the mph would have been more.
Old 11-13-2007, 12:48 AM
TwoFast4Lv's Avatar
very nice. We have a few nasty ones around here but not putting the numbers down!
Good deal!
Old 11-13-2007, 06:40 AM
LS1 SPEED's Avatar
yes..awesome times, but you should pick up more then 2 mph on a 75 shot.
when I had my unported 2.76 car I seen over 100 HP on the dyno & 6 mph on a 75 shot..these things really like the N20 and it gains power by both cooling the intake charge and the n20 itself
good times either way
Old 11-13-2007, 09:44 AM
Black03's Avatar
Check out my 60' times I came out the hole a lot harder on the juice pass. My blower pass I spun out the hole pretty good, so the mph was higher. On the juice pass I actually bogged quite a bit, the car just had enough tq on the spray to muscle off a good short time. Had I got some tire spin coming out the hole the car would have gone 10.5-10.6 with a much higher trap. Just as an example I've trapped 107 before in the 1/8th on the 40 shot I had in the car coming out the hole spinning...
Old 11-13-2007, 04:18 PM
LSWaaa?'s Avatar
Pretty impressive times. What kind of tire were you on? Did you hit nitrous out of the hole?
Old 11-13-2007, 04:35 PM
Steve C.'s Avatar
very impressive. i cant wait to take my car to the track with the new KB.
Old 11-13-2007, 05:36 PM
Black03's Avatar
I was on 26x10.5x15 ET Streets, and yeah I was spraying straight from home....
Old 11-13-2007, 08:09 PM
RamAir02TA77's Avatar
We have a 03 cobra we race the car has gone the a best of 10.99 @ around 123mph with stock irs unported eaton pretty much full weight minus spare tire jack pro stars and tubular k. He added 125 shot and made around 600rw or something car made around 460 on blower. The car then went and ran 10.59 @ 125 so it only picked up 2 mph the stock blower seems to not work well with nitrous as the power was falling off above 5k. This year he has gone 11.00's with the car blower only and ran 10.83 on nitrous. The blower seems like a restriction on the spray and therefore doesnt mph well as it just seems to make torque. He decided to just run the car on blower now as it runs good for a unported eaton car.
Old 11-14-2007, 09:13 AM
Black03's Avatar
These cars respond incrediblty well to nitrous actually. I picked up 3/10 on a 40 shot, and 4/10 bogging the launch on a 75 shot. Like I said the mph is low because I bogged out the hole, check out some of my other time slips I've trapped higher on the 40 shot before. As far as your buddy, he obviously drives the hell out of the car but the stock unported blower levels off on power after 5k with or without nitrous. He'd see a good bit up top by porting it.
Old 11-14-2007, 04:05 PM
Black03's Avatar
A little bonus footage, me racing a H/C/longtube Viper....
http://s230.photobucket.com/albums/e...bravsViper.flv
Old 11-14-2007, 08:05 PM
He did homeport the blower this year and didnt pick up anything with the same thing pretty much happened. He then swapped with his buddy for a stock unported blower again. He did gain about 20rw with his homeport. Obviously you have a better port tb and plenum but it seems as he just picked up torque and torqued his way through the 1/4. Do you plan on upping the shot? I wonder if maybe a 75 shot will work better then a 125 with a stock blower do to restriction.
Old 11-14-2007, 09:28 PM
NJSPDER's Avatar
blower + nitrous = 10's?
sorry, but even at full weight i can't give much credit to needing two power adders to run 10.7's.
Quick Reply: 10.73 @ 130 Full Weight Ported Eaton Cobra with 75 shot....
