LMR Turbo Camaro
LMR Turbo Camaro
We took the car back out a few weeks ago for our first True Ten Five event of 08. We decided to try the 114mm turbo because we knew it was going to take a low 4.80 in the 1/8 to win the event. Last time we took the car out we were struggling to get the 114 to spool. After a little tuning on the computer from Josh, we finally got the car to leave like it should with the 114mm turbo. You can see in the video how the car pulls great to the 330 marker, then just falls on its face. We are running a Weldon 2345 fuel pump good for 2400hp and 160lb injectors. This 114mm is making so much more power than the 106. At 31lbs of boost on each turbo, the injector duty cycle goes from 82% with the 106 to 96% with the 114. I never thought I would see the day when we would max out this fuel system.
http://videos.streetfire.net/video/O...way_157130.htm
Steven Fereday
Late Model Racecraft
713-466-9900
Latemodelracecraft.com
Steven Fereday
713-466-9900
I need an update, I want to see that 'bird fly!
Shane
Holy shat, that twin turbo 6X Camaro pulled the wheels at the end of the 1/8 @ 165mph! BTW you need to get some hot chicks in bikini's to wipe you car down...
