changed from a 26" to 28" tire................
Old 06-05-2008, 01:56 PM
getusumws6's Avatar
Default changed from a 26" to 28" tire................
went to the track after changing tire sizes from a 26" 275/50/15 to a 28" 275/60/15 mt dr. figuring I would mile an hour a little better and did just the opposite. went from a consistant 11.9x to a 12.3xx and from 114mph to 109mph. i guess its time to change gear ratio in the 9" to a 4.11 or 4.30 (i have a 3.70 btw). alittle disapointed in a way,but gears are cheaper than a new set of mt dr's.
Old 06-05-2008, 02:17 PM
dlove's Avatar
have you da corrected both runs to use a control to see the real difference.
post the track name/zip/date/time and i will do it if you want
Old 06-05-2008, 02:26 PM
getusumws6's Avatar
the air was at 3200ish. KCIR 6/4/2008 7pm-9pm , track temp was 101* and the car was dead hooking. played with the suspention for a bit but all the runs were carbon copy of each other. i'm doing some math with my 60's and 330's to see whats up.
Old 06-05-2008, 02:39 PM
dlove's Avatar
i didnt even notice you are local. kcir is 798' up
what is the date for the other run?
Old 06-05-2008, 02:46 PM
getusumws6's Avatar
may 10th 2008 same track 10:30 to 11:30 am, the last time i went to the track anyways. and thanks for any insight and help you are providing.
Old 06-05-2008, 02:50 PM
dlove's Avatar
last night was not good lol
with new tires 28
Density Altitude = 3228 feet ET MPH
Uncorrected 12.3 @ 109
Corrected 11.83 @ 113.2
with old tires 26
Density Altitude = 1187 feet ET MPH
Uncorrected 11.9 @ 114
Corrected 11.75 @ 115.45
so not as bad
what was the 60' times?
Old 06-05-2008, 02:53 PM
camscam02's Avatar
it doesnt seem that you are trapping to high. and ecsp. with 3.70 gears those 28's are hurting you. If you switch to 4.10's and go back to a 26 inch tire, I think you will knock off alot on your time.
what do you trap and what is your rev limiter set at?
Old 06-05-2008, 03:05 PM
getusumws6's Avatar
with new tires 28
with old tires 26
so not as bad
60's were 1.67 all runs, usually they are 1.51x consistant on .410 tree w/.01x r/t's
Old 06-05-2008, 03:07 PM
dlove's Avatar
so the 26's were 1.51? and just now it went 1.67?
Old 06-05-2008, 03:10 PM
getusumws6's Avatar
i was trapping 109mph all night. rev is set a 6400rpm. on the 26" tire i would trap 6,000 rpm and now w/ the 28" i trap at 5600rpm (which i had planned on). this winter i was going to do a new cam (trex or ms4) and planned to upgade to a 4.30 gear anyway, but a 4.11 for now. oh so much wasted money lol.
Old 06-05-2008, 03:12 PM
getusumws6's Avatar
correct, and that was dead hooking everytime.my car ran same 1.67 60's last summer with 10 bolt w/ 3.73, stock tq arm, stock shocks.
Old 06-05-2008, 03:14 PM
dlove's Avatar
well if the faster run was with a 1.51 and the 28 with a 1.67. that would be the difference.
you might just need more gear like you said to get it out. or look at the suspension and see if it is now maybe bogging some
Old 06-05-2008, 05:36 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
The 26's were probably better for getting you through the run at near the power point at the end versus the 28's and losing a bit in the rpm range.
Derek
Old 06-06-2008, 12:23 PM
BADSZ28's Avatar
Yeah I would go 4.11 on the 28s. Anything bigger you will run out of gear if you decide to go faster.
Old 06-06-2008, 01:03 PM
chrs1313's Avatar
why would you think your mph would go up going from 26s to 28s...
that would be like saying going from 3.73s to 2.73s would increase your MPH it is quiet the opposite...
that is why i didnt wanna have to go to 28s yet cause it is going to knock my mph down...without a gear change
Old 06-12-2008, 11:26 AM
Fred O'Bannion's Avatar
just spray the hell out it...that should solve it!
Old 06-14-2008, 10:40 AM
ABA383's Avatar
Yeah as others have said if you go up in tire diameter you'll need to go numberically up in gear to compensate....I went from 3.73s and 26s to 4.10s and 28s and went from 119.75 to 121.18 with no other changers with very similar track conditions...
--Alan
Old 06-16-2008, 09:11 PM
BADHAWK51's Avatar
Alan it seems to me that going from 3.73s and 26s to 4.10s and 28s would be a wash but if you picked up 2mph thats awesome. I recently went to the track to test out my combo ran all motor 4000 nitrous converter (tight) 275/60/15 drag radials 28in ran a best of 4 passes 11.4 @ 119 mph 96 1/8 on a 1.731 sixty the car would not leave hard. I just put some 4.10's in and was thinking of running a 26in tire for motor runs then switch to 28's for the spray hoping the car will leave harder on motor and pick up some et and mph. Last resort will be have the stall loosend up a little. The car has all the good suspension stuff.
What you think ?
Old 06-17-2008, 08:56 AM
BADSZ28's Avatar
What you think ?
Yep. This is the way to go IMO.
Old 06-17-2008, 05:06 PM
BADHAWK51's Avatar
Thanks, I think so to.
Quick Reply: changed from a 26" to 28" tire................
