6/19 test and tune
Old 06-20-2008, 07:47 PM
LTLRDSS's Avatar
Default 6/19 test and tune
track prep was bad and it rained earlier that day so im sure that didn't help. i was spinning and wheel hoping
me and my friend derek. our cars are within a tenth of each other. this was my best run 13.51@107 with a 2.21 60ft
and an in car with me (listen for the wheel hop)
Old 06-23-2008, 08:49 PM
Carter01's Avatar
First pass sounded good but the second pass you bogged it pretty bad. It is actually better to spin a little then to bog out of the hole. You will probably net the same 60ft spinning a little as you did bogging but you will reap the benefits on the big end.
As far as the wheel hop goes, man you need to let off when that happens. Wheel Hop = Breaking Rearend Parts. I don't know how much you know about wheel hop but you can do some searches and find out how to correct it. Just to throw out a few hints, new shocks? aftermarket LCAs? aftermarket springs?
Good Luck
