Got to the track last night for some shakedowns.....
Old 06-26-2008, 05:15 AM
Loudmouth LS1's Avatar
Default Got to the track last night for some shakedowns.....
Went to the new 1/8th mile track in Miami and I got a **** ton of runs in last night. Not the greatest track though and stay away from the right lane, at about 6000 rpm in 2nd all the sudden I blew the tires off and hit the rev limiter, was like wtf!!!! But anyways, on to the good stuff! The intake killed my low end bad, I can't even see 4000 on the tbrake anymore, only goes to maybe 3800 and it's coming out even doggier than ever, couldn't go better than a 1.75 60'!
Here's the good news though, it picked up big time in the high rpm range, you can really feel her start to move over 5000 rpm (which on spray i'll never be under!) and she now wants to pull to 7500, tried shifting at 7000 and she just wanted to go more, so I worked my way up to 7500 and that seems to be the sweet spot and I don't really wanna go over that anyways! So anyways, here it is, she went 100.8 mph but at only a 7.2 et cuz of the horrid 60'. She definately picked up mph wise, the only time I ever got close to that on motor with the old setup was one time it went 100.7 in 40 something degree weather and she had 26" tires on and 60' 1.60 and had 29 degrees of timing. I was on my 28's, and only 24.5 degrees of timing cuz I was being safe cuz of the added compression, she was smooth and strong, so i'm gonna try bumping that up to around 27 or so and see what happens if I can get out there again saturday. It was hot and humid as ****, normally in this weather and on the 28's with the old setup she went 98 - 99, so like I said, she definately picked up, and I have a feeling she'll pick up a lot more in the 1/4 than she is the 1/8th cuz of how doggie she is down low, wish Moroso was open so I could find out, but I will have to wait till I can get to BMP!
Old 06-26-2008, 10:36 AM
tektrans's Avatar
Nice first time out with the new set up.
She'll get faster.
Old 06-26-2008, 11:04 AM
She'll get faster.
Thanks man, I can't wait to get the spray back on her, I gotta change the oil tonight, still on the break in oil, then tomorrow i'm gettin on my buddy's dyno just to see where the powerband is at and make sure i'm not reving it too high goin to 7500 and gonna see what kind of gains I get from some more timing.
Old 06-26-2008, 04:26 PM
10 & 11 Second Club
Caveman's Avatar
Congrats on getting some runs. It really sucks to go along time without dragracing, good luck dialing in the setup.
Old 06-26-2008, 05:03 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Sweet you got her back to the track. Good luck on dialing her in. Please keep us posted.
Coach
Old 06-26-2008, 05:17 PM
Thanks dude, this year felt like the longest year of my life!
Old 06-26-2008, 05:25 PM
Coach
Thanks Coach, how's this for a decent bracket car, here's all the runs for the night (or at least all the slips I can find, I made 8 runs, can only find 5 slips):
7.304
7.309
7.280
7.270
7.259
She's fairly consistant. She slowly went faster as I was dialing things in like shiftpoint and so forth, the 7.28 and 7.27 were on the same settings, and same goes for the 7.30's, they were on the same setting as each other at that time.
Old 06-26-2008, 07:13 PM
venom ws7's Avatar
Great shakedown passes man Congrats the car fly for sure.
any vids???
Old 06-26-2008, 07:17 PM
any vids???
Thanks man, there are vids, just waitin on my buddy who took 'em to get 'em off the camera and then I will put the links in here! I can't wait to see 'em myself!
Old 06-27-2008, 08:14 AM
8 second mod
Noyzee's Avatar
good for you, sounds like she is working. i told you she would pick up.
now for out of the hole, what you need to do is a 2 step. set it around 3200 to start, let that converter flash and you will pick up in the short time
sounds like that converter however even with the 2 step probably wont go better then 1.5x or so. sounds to tight till you loosen her up with a little go go juice.
once you spray it, you will also pick up alot.
Old 06-27-2008, 08:36 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Congrats.
So you think the single plane shifted up your power band a lot?
Old 06-27-2008, 08:39 AM
8 second mod
Noyzee's Avatar
Congrats.
no question it does. esp if you port them out and open everything up on the runners and top.
i picked up pretty big on top with my set up
Old 06-27-2008, 11:04 AM
Thanks dude, I can't wait for the spray, gotta recoop funds, hopefully in a couple months! Been working as many saturdays as they'll let me!
Old 06-27-2008, 11:06 AM
Congrats.
Definately!!! You can really feel it kick in at like 5000, almost feels like I hit a little shot! And she pulls hard from then on and definately wanted to go past my old shift point of 7000.
Old 06-27-2008, 11:44 AM
1QuickT-A's Avatar
Awesome to see you get her going man.. I'm hoping to go Sunday if it doesn't R***!! Those intakes love the top end. I know that mine does. I only 60ft 1.6X with my tight converter and no bottom end power but I was 7.00 @ 102 with 25*s of timing and shifting at only 6700rpm. I'm hoping to go 6.70s with 28-29*s of timing and the new headers and exhaust setup also minus 100lbs..
Keep me posted on what your car does.. Especially when you spray it..
Old 06-27-2008, 11:53 AM
8 second mod
Noyzee's Avatar
my car with the nitrous converter runs in the 1.6 off the brake. put the 2 step in at 3300 and she runs 1.4x now.
6.3x @ 107-110 in the 1/8
thats with 32* of timming
but i have more compression and more cubes.
3400 pounds
D, your car is also geared for 1/4 mile. if you geared it for 1/8 that 60 would get alot better
Old 06-27-2008, 07:16 PM
Just got off my buddy's dyno, it's a mustang dyno, so it reads a little lower than a dynojet and i'm very happy, and the powerband is right around where I thought!! The two runs are the difference between 24.5 degrees of timing and 26 degrees:
Old 06-27-2008, 08:02 PM
7 Second Club
Villain281H's Avatar
Location: Gainesville, Florida # of drag strips runs: ?!?!?
Nice start D! As mentioned, it'll get better and you'll get some faster slips yet.
Keep us posted!
Derek
Old 06-28-2008, 05:19 AM
3400 pounds
Yeah, I think the gearing is gonna be perfect for the spray, if she runs as well as I hope, i'll probably be right on the light goin through the traps. Hey Brad, let me ask you a question, i'm running a set of PRC gold dual valvesprings in my heads and one of my friends was asking me if I asked anyone if they are safe to spin to 7500, what you think, I shouldn't have any problems with spinnin her to 7500 with them, right? I'm not even sure who to call to ask that question.
Old 06-28-2008, 08:55 AM
gator's 99TA's Avatar
i think the spring is just fine. is the lifters sufficient?
