So sick of this S@*T!
Old 07-12-2008, 01:33 AM
shannon's Avatar
Default So sick of this S@*T!
Ran twin 11.0's@126 a week or so ago....Weather bad again tonight so I thought I would be smart and up the shot to 175....Left timing where it was and just added 3 gallons of C-12....And what do I get.....**** THIS ****, im done for a while, patience is about gone....I cant break into 10's with a 128 trap???? I SUCK.......
Old 07-12-2008, 01:41 AM
R1ch's Avatar
Sucks dude.
Old 07-12-2008, 04:24 AM
tektrans's Avatar
That sucks. Your 60' is pretty bad. You're probably leaving close to 4 tenths worth of ET just on your 60' alone.
Get that 60' down and you'll never see 11's again.
Don't be so mad-this is supposed to be fun.
Old 07-12-2008, 04:49 AM
nighthawk15's Avatar
Nothing to add to this. Pretty much everything I was gonna say.
Old 07-12-2008, 05:58 AM
Race your car!
JL ws-6's Avatar
Honestly, the fact that you're even going 11.0 with a garbage 1.7 60 foot is pretty impressive IMO.
That 60 foot is a good time for a stock internal car with a converter and a set of drag radials. For a h/c car with nitrous, it's terrible. Nitrous makes all the power the instant it hits, so to not be able to 60 foot any better then that means you've got to be spinning your brains out.
I don't know what you're running for a tire, but if you're not running a real boas ply slick on the car, put some on it, on a 15 inch rim. That alone will probably knock /3 off the slip, simply because if the car does spin at least those tires will recover and get you going in the right direction even if the suspension isn't perfect.
Old 07-12-2008, 09:53 AM
shannon's Avatar
15's are my next purchase...I was using my stock 17's with MT ET streets and spun with them...I borrowed a friends 16's off a T/A and now as soon as nitrous hits(as soon as I let the clutch all the way out) im going sideways through 2nd....With the 150 shot I will get a consistant 1.6 and 7.1's in the 1/8th with the 17's...I thought more sidewall would help with the 16's........
Old 07-12-2008, 10:53 AM
Navy David SS's Avatar
You said it all yourself. Tires. Get a good set of 15's and you'll see 10's. Easy with the 4 letter words. Don't beat yourself up. Just fix the problem (60's suck as said before) and move forward.
David
Old 07-13-2008, 12:04 PM
"The Drag Racing Director"
Coach 02 A3 Z/28's Avatar
Tires my Brother. good luck.
Coach
Old 07-26-2008, 12:40 PM
svtwhat?'s Avatar
i dont have to repeat anything anyones said... but your times for those 60's are pretty good... 128 mph too! that car has 10s in it all day and thats a fact.
Old 07-26-2008, 02:08 PM
LM97Z's Avatar
Like said, DITCH the Radial, go bias, get some true slicks or even ET streets, screw the rims, play with tire pressure, you'll be amazed what the car will do leaving the line, 128 is a solid mid. 10 sec. pass, i mean SOLID, you should start seeing some 1.5 60fts with the slicks, just carry a neck brace, you may need it lol. In the end, if your spinning that bad now, you'll gain a good 2 mph once you hook good, thats 130, easy 10.2-10.40 pass. Just 2 weeks ago, a 99 TA went 10.3 @ 129 on the bottle (on slicks)
Old 07-27-2008, 07:55 AM
StreetStalkerZ's Avatar
Your MPH will drop down when you stick a good 60ft. but your ET will dip you into the 10s easy. I'll take ET over MPH any day!
15 inch wheel with a 26x11.5 ET Street or a 26x10 ET Drag will have you grinning from ear to ear when you get your timeslip.
Quick Reply: So sick of this S@*T!
