Cam only trap speeds
Old 09-02-2008, 01:45 AM
ZTwentyAteU's Avatar
Default Cam only trap speeds
What kind of trap speeds are you guys running with your cam only cars?
I'm trying to figure out why my car was trapping so low the other night at beech bend(other than 100percent humidity)
My TA has a 228/230 .579 .581 114 in it and completely fresh, less than 250miles motor in it and was only trapping 110mph. Its a m6 w/ 4.10 gear.
The same cam in an identical motor in my camaro was trapping 114-115 w/ an auto and 3600 Vig.
Is it my tune thats off too much?
BTW fastest I ran was 12.83@110, 2.03 60ft. LOL
Old 09-02-2008, 10:45 AM
4yall2nv's Avatar
i usually trap around 114-116, cam only and run around 11.6
Old 09-02-2008, 11:03 AM
TA1364's Avatar
111, sure would be nice to be at around 115-116.
Old 09-02-2008, 11:35 AM
30th t/a's Avatar
110 Is Definately Low For A Cam & Bolton, 6 Speed Car.
Old 09-02-2008, 12:23 PM
procsls6's Avatar
I've trapped as high as 94.77 in the 1/8 and 117.8 in the 1/4 in the heat.
Old 09-02-2008, 12:52 PM
purdueranger's Avatar
M6 cam only, I trapped 117-118 full weight in a Camaro. Now that I lightened the car up, added a better clutch I am hoping for a 120 this Friday.
Old 09-02-2008, 02:28 PM
Dragkid1917's Avatar
118.8 MPH with ls1 intake and throttle body.
Old 09-02-2008, 02:32 PM
I think I figured out why it was running out of power. New times this weekend!
Only slow cammed car ive ever had. I've gone faster than that w/ a bolt on car
Old 09-02-2008, 04:08 PM
SIC LSX's Avatar
i trap 11.60 118mph full weight minus spare tire and jack, M6, t-top car with 255lbs driver, Stock rear 10bolt too
Old 09-02-2008, 04:29 PM
BLK85's Avatar
111 average 112 is not to unheard of, can only manage 12.60s so far. Thats with a Hot Cam.
Old 09-02-2008, 05:15 PM
bad6as's Avatar
torquer 2
3.90s
race weight 3675
116mph +2000da
Old 09-02-2008, 07:34 PM
CanuckSS's Avatar
Just over 127 mph Trex-Under 3000lbs race weight and a 6 speed.
Old 09-02-2008, 07:37 PM
bad6as's Avatar
you you go by the 10 hp is .1 and 100lbs is .1 it comes out right.
me 3700 you 2900. thats 800lbs or 8mph
trex vs torquer 2. t rex is bigger and makes more power theres the other 3mph
Old 09-02-2008, 08:25 PM
lilbuddy1587's Avatar
G5X3 112+4, true duals, lid and tune
117mph
Old 09-02-2008, 10:04 PM
SIC LSX's Avatar
hell a 1999 just bolton a4 car with tci 3600 stall 3.73's here is running 12.1@111mph. Full weight minus spare tire and jack on convo pro drag wheels
Old 09-03-2008, 11:19 AM
TA1364's Avatar
Damn you guys getting 115+. What am I doing wrong?
Old 09-03-2008, 12:03 PM
camscam02's Avatar
123 in an auto at 3400 lbs
Old 09-03-2008, 08:38 PM
Demonicbird00's Avatar
110 stock
117 SI
127 cam only
-brandon
Old 09-03-2008, 09:43 PM
LS1Z28-00's Avatar
dont feel bad my car only traps 92 in 1/8th with heads and cam. its not tuned yet though and at 1000 ft elevation.
Old 09-06-2008, 10:41 AM
chrs1313's Avatar
230/230 cam with ls6 intake and stock 3.23s...
122mph in 0 da weather with raceweight at 3350ish
Quick Reply: Cam only trap speeds
