11.85 @ 112 m/t radials not cutting it
Old 09-21-2008, 02:56 PM
TA1364's Avatar
Default 11.85 @ 112 m/t radials not cutting it
Well I found some m/t to borrow and went 11.93 @ 112 with 1.61 60' and 11.85 at 112 with 1.59 60'in time runs before elminations. Once elminations started my car would not hook up. I managed to make it to the finals 6 rounds later but spinning everypass high 1.6 to 1.7 short times. Finals spun the worse, 1.81 60' and I lost. Tires started out at 16 psi and I went to 14 but did nothing.
I thought using some mt radials would help hook better but it only did it twice. Would a et street hook more consistantly than the radial?
Old 09-21-2008, 09:33 PM
Deerhunter-Z28's Avatar
Sounds like it was hooking just fine before the track went away .
Old 09-22-2008, 01:50 PM
MATTREDSS's Avatar
^^^^^ Yeah I agree. Did they prep the track before eliminations started?
Could you post the breakdown of the slip, the 11.9 and 11.8 pass. I just want to compare it to my car, I'm trying to get 11s with no cam. I have mickey radials as well, I noticed I gotta get them real worm to hook. What are you leaving at?
Matt
Old 09-22-2008, 02:02 PM
Photochop's Avatar
You shouldn't ever need to lower the PSI in those MT radials that low. They typically hook best around 18-22psi hot. Sounds like the track prep was suffering as the night went on...
Old 09-22-2008, 03:38 PM
Elite_Hot_Rod's Avatar
No ET Streets will not hook more consistantly than their drag radials. We regularly cut 1.3X 60fts and have had a best of a 1.27 60ft on the radials. I have to agree with the others, the track went away. I'd bet you started off with a nice warm well prepped track surface and the cooler it got later in the day/night the track went away. I would also bet that if you checked with some other racers that were at that track that night they would say they had the same issue.
Old 09-22-2008, 06:40 PM
TA1364's Avatar
Heres 2 time runs at 12:45 and 1:15
1.61
7.56@90.35
11.93@112.69
1.59
7.50@90.58
11.85@112.70
First round was at 3:45, 1/4 are pointless since I could only dial 12.00 so I didnt run it all the way out.
First round
1.69
7.59@90.96
Second round
1.72
7.64@90.96
Fifth round
1.67
7.51@91.49
Finals
1.81
7.76@91.25
Old 09-22-2008, 06:43 PM
TA1364's Avatar
Track prep is always the same thats why I want more of a slick than a radial.
I do have almost stock suspension with just lca and no front sway bar.
Old 09-22-2008, 11:25 PM
It's the track surface tempature cooling off that caused your problems.
Old 09-22-2008, 11:32 PM
waterbug1999's Avatar
Now that you have some traction, does you car squat pretty hard???
Old 09-23-2008, 10:41 AM
TA1364's Avatar
There is no way the track surface was cooling off at 345 in the afternoon. In the later rounds yes that probably is an issue.
Old 09-23-2008, 10:43 AM
TA1364's Avatar
Not sure. I cant really tell when I am driving.
Old 09-23-2008, 11:54 AM
spec_j's Avatar
i run my M/T's at 13-14 PSI and hook dang good everytime...till the track goes to crap. Seems like as everyone else said that was the problem.
Old 09-23-2008, 12:28 PM
TA1364's Avatar
Probably true. I'll be going to Norwalk here in a couple weeks, that should solve track prep issues.
Old 09-23-2008, 01:39 PM
Unstang's Avatar
What size are you running? I have the 275-40-17s & 275-50-15s & they both work really well. The only time I have trouble hooking, it is because I don't get a good burnout. (No line lock)
I run them 18-20 psi, 1.51 is my best 60' on the 15s, 1.61 on the 17s.
Old 09-23-2008, 02:35 PM
TA1364's Avatar
255-50-16
Old 09-23-2008, 03:35 PM
12secSS's Avatar
To determine if it was a track prep issue, what were other cars 60's and ET that you ran against. Compare their times on your slip and that should give you an answer. I wouldn't rule it was the track fault without merrit. It could have been too low of a tire pressure, not a good consistent burnout, or the tire's sidewall is too stiff for your application. Which an softer sidewall (ET Street) may solve.
Old 09-23-2008, 03:51 PM
TA1364's Avatar
Yea I have a set on the way. Luckily I didnt buy the radials yet I just borrowed a set. Honestly I dont think anyone else was running a radial. A few cars 60' close to mine but all had slicks.
Old 09-27-2008, 06:05 PM
TA1364's Avatar
Ok I have ET streets and same exact bullshit happen from last week. Hooks in time runs, eliminations it spins. This week lost third round, had the tree but went over a tenth off. Someone mentioned the car isnt getting enough weight transfer and its unloading the tires right after the converter hits. I dont really want to spend any money on suspension with only a few races left. I guess I will just add weight in the rear.
