Click here to visit LS1Tech
Click here to visit Performance Trucks
Click here to visit Mod Motor Tech
Click here to visit Modern Hemi
LS1Tech Wiki
LS1TECH
Go Back   LS1TECH > RACING DEPARTMENT > Drag Racing Tech
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into LS1Tech.com, click logo to login
Drag Racing Tech
Rules | Safety | Setups | Hardware | Methods
Sponsored by
Improved Racing Products
Click Here
Old 10-13-2008, 09:20 AM   #1
Trader Rating: 1
Default My weight loss plans
Hey guys
Im going to be doing some dieting to my camaro come next spring and was wondering if anyone had any other ideas for me, i have looked at that list a ton of times.
1) back seats, mats
2) front seats, mats, installing race seats
3) entire exhaust (catback, y pipe, cutouts) to just mufflers off headers
4) AC
5) all the emission stuff
6) racing rims with new rubber (15x5 fronts so i can DD)
What else could i do thats fairly cheap and will still allow me to DD? i figured all this would take off 250-300 pounds.
__________________
2005 Silverado RCLB 4.8L 4x4
Slowhawk Tune (so far)
stumprrp is offline   Reply With Quote
Old 10-14-2008, 06:00 PM   #2
Trader Rating: 1
no suggestions at all?
__________________
Old 10-14-2008, 06:06 PM   #3
ndfrsd6's Avatar
Trader Rating: 1
Send a message via AIM to ndfrsd6
look in the weight reduction sticky in this section it's loaded with ideas
__________________
01 Camaro,LS2 402ci, SI/RGR 241 heads, 90/90, Hooker 1 7/8 LT's w/ TD's, Strange 12 bolt w/ spool & 4.11, TH400 w/ UCC 5500 stall and a LITTLE weight reduction
www.ls1speed.com
10.25 @ 130.18 w/1.40 60FT. N/A (race weight-3090) (FOR SALE)
track results of new setup http://www.youtube.com/watch?v=eHUgbVBMwH4
ndfrsd6 is offline   Reply With Quote
Old 10-14-2008, 06:14 PM   #4
Trader Rating: 1
as i stated ive read that sticky many times however im not sure if i can do anything else so i can still drive my car daily, alot of the safety stuff i want to keep.
__________________
Old 10-14-2008, 06:24 PM   #5
ndfrsd6's Avatar
Trader Rating: 1
well your stuck between a rock and a hard place ....it will be hard to have both light weight and dd safety . you can only go so far till your spending money on light weight stuff k-member, a-arms,ect and a lot of people dont want to drive without their bumper supports and hvac and door bars
__________________
www.ls1speed.com
Old 10-14-2008, 06:26 PM   #6
ndfrsd6's Avatar
Trader Rating: 1
oh yeah front sway bar and mounts, cruise ,traction
__________________
www.ls1speed.com
Old 10-14-2008, 06:28 PM   #7
Trader Rating: 1
i was thinking about ditching the sway bar and the traction control as well, thanks for those.
__________________
Old 10-15-2008, 01:49 AM   #8
snake charmer's Avatar
Trader Rating: 115
battery relocation to the trunk would take a dent out of your numbers . abs , power steering , the stuff under your carpet . saftey stuff like mentioned front and rear bumpers , bars in doors , air bags . also the 15s assuming they are weld or similar weight should take another good chunk vs. factory wheels .
__________________
2000 TA M6 346ci
Wait4me tuned - 243s - FRE 92.xx TB - Fast 92.xx -224 Cam - SD Tuned - 42lbs inj. - Custom CAI - Custom Duals - SLP Pulley - Z06 Chrome Shoes 17s/Front 18s Out Back
snake charmer is offline   Reply With Quote
Old 10-15-2008, 02:18 AM   #9
60ftkiller's Avatar
Trader Rating: 0
Yeah I'd get rid of the power steering assembly. I run on skinnies all the time and its not bad at all. Especially with the AC/HVAC out, tubular K member, no front bumper support, LTs took some weight off, solid motor mounts, lighter trans.
60ftkiller is offline   Reply With Quote
Old 10-15-2008, 07:49 AM   #10
BlackScreaminMachine's Avatar
Trader Rating: 16
Pulling off the insulation backing on the carpet is a good idea.
__________________
2002 Navy Blue Metallic Trans Am.
FS: Stock GM & Ram Clutch Master Cyl. LOW MILES
http://www.ls1tech.com/forums/lsx-pa...l#post12706945
BlackScreaminMachine is online now   Reply With Quote
Old 10-17-2008, 02:18 PM   #11
Shoaf85's Avatar
Trader Rating: 9
Quote:
How much does this normally lose?
__________________
03 Cobra 2.3 Whipple 630/590 SOLD
00 H/C/I FRC Corvette 10.73@130 SOLD
http://videos.streetfire.net/video/F...107_149190.htm
02 Camaro Turbocharged on E85
Shoaf85 is offline   Reply With Quote
Old 10-17-2008, 02:20 PM   #12
Trader Rating: 16
Quote:
Had to be around 15-20.
__________________
Old 10-17-2008, 04:40 PM   #13
LM97Z's Avatar
Trader Rating: 4
There is alot of weight that can be taken out of these cars, i would also look at that panal under the steering column above your legs, that sucker is heavy, you can fab up something light & paint it, that small hatch in the trunk area is worth alittle, anything little that you can find to take out, do it, it'll add up, 300-400 lbs. shouldn't be too hard if you really look, that'll put your weight between 3000-3100 lbs. without a driver, thats pretty light for these cars IMO. this is what i would take out.
All AC components
PS
All smog stuff/air pump ect.
Spare/jack
Carpet insulation
Plastic panel under coulumn
All seats, replace with race seats
Drag light wheels
Front sway bar
Re-locate battery too trunk
Remove exhaust, bullets after LTs
There is alot of plastic panals all over that can be removed, it may only add up to 20-30 lbs., but thats 20-30 lbs. less, just DON"T remove that air damn for the radiator.
I'm sure you can find another 50+ lbs. on little stuff. You should invest in some SFCs at the least, this will add weight back in of coarse, but will keep the car from flexing.
__________________
97 Z28, CAI, M6, Moser 9" with 4.11s, custom 3" steel DS, BMR TA, Pacesetter LTs & Ory, 10.2mm wires, walbro 255 pump, B&M shifter, centerforce clutch. Hoosier 26" DRs. 159K miles & still going strong. Madtuner tune, On the bottle now.
Best: 60ft. 2.00 8.81 @ 81, 13.54 @ 101.95
On 100 shot: 60ft. 1.80 12.01 @ 115.06
75 Duster: 10.87@123.58 NA
LM97Z is offline   Reply With Quote
Old 10-17-2008, 04:49 PM   #14
Trader Rating: 1
An easy 10-15lbs can be seen in removal of the windshield washer tank and fluid. The tank is usually 3lbs or so, the fluid , depending on how full, is 10-12lbs. You can also lose the wipers for 5-6 lbs.
__________________
Lite the fires and turn the tires
Evilways is offline   Reply With Quote
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
LS1TECH - Archive - Top
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
Advertising - Terms of Service - Privacy Policy - JOBS
