Dave Morgan Chassis seminars
"Dave Morgan Saved Me a Bunch of Money" (Tex Ooten, Norwalk, Ohio)
* Racers are learning the value of Dave Morgan's knowledge
* New Setup Workshops to begin this year
* Seminar registration information at the end of the announcement
SETUP WORKSHOPS:
In selected locations, I'll teach racers how to setup a chassis using actual cars. Racers will get a chance to learn these techniques in a hands-on environment. This is an embrionic program so if you have questions, please call me at 567/242-9779. In the workshops we will...
* Establish corner weights with springs and ballast
* Locate the Center of Gravity
* Map Instant Centers
* Square the rearend
* Align the front end
LOCATIONS, HOSTS AND DATES:
(More dates and locations will be added)
* Denotes special Set-up Workshop
Fort Worth, Texas: Painless Wiring 817/455-1405 November 22
Denver, Colorado: TC Performance 720/974-0888 January 17-18 *
Lebanon, PA: Scott's Transmissions 717/273-9944 January 24
Detroit, MI: Racefab 989/692-7223 January 31
Dayton, Ohio: Kammer & Kammer 937/237-8675 February 7
Lima, Ohio: TBA 567/242-9779 February 14
Columbus, Ohio: TBA 567/242-9779 February 21
Chicago, Illinois: Alston RaceCars 847/395-3500 March 7-8 *
Norwalk, Ohio: TBA 567/242-9779 March 14
Indianapolis, Indiana: Joe Barscz Racecraft 317/892-4054 March 21
Newport News, VA.: Williams Perf. AutoWorks 757/591-7110 March 28-29 *
Ask Yourself These Questions to Determine if YOU Need This Seminar ...
* Do you know how much weight transfer you are getting?
* Do you know how much load you are getting in your rear suspension?
* Can you predetermine your G-Force at the launch?
* Where are the most common areas of chassis flex?
* How can inspecting the tin work help you locate flex?
* What is frame rail shift? Which frame rail goes where?
* How can you locate frame rail shift??
* What does caster offset do?
* What is the advantage of storing energy in a suspension spring?
* How can you store energy in a suspension spring?
* How can you tell if the shocks are valved too light for a car?
* How can you tell if the shocks are valved too stiff?
* What does adjusting the shock extension rate do to a suspension?
* What does adjusting the shock compression rate do to a suspension?
* How do you install and set-up a ladder bar suspension?
* How do you install and set-up a four-link suspension?
* How do you tune with shocks?
* What is the Rear Roll Center and how does it differ with the various locating devices?
* Which locating device is best for your car?
* What effect does your Center of Gravity (CG) location have on your rear suspension?
* What is the actual difference between a ladder bar and four-link suspension?
* How do you determine the CG location in a car?
* What is a linear shock curve?
* What is a digressive shock curve?
* How can you determine if your problems are related to the frequency of the suspension springs?
NEW COURSE OUTLINE:
The goal of this course is to teach drag racers how to balance their suspension combination. Some racers don't know if th ey are hitting the slicks too hard or not hard enough. At this seminar, they will learn how to find this out.
I. WEIGHT TRANSFER
A. Drive wheel torque
B. Wheel thrust
C. G-force
D. Determine the amount of weight transfer
II. Center of Gravity
A. What it is
B. How to locate it
C. Polar Moment of Inertia
D. Roll centers
III. A brief look at chassis flex
A. Frame rail shift
B. Chassis twist
C. Rear Housing flex
IV. A brief look at bind
A. Rod ends
B. Ball joints
C. Mechanical issues
V. Shocks and Springs
A. Storing energy in the springs
1. Advantages of a light spring
B. Sprung/Un-sprung weight
1. Catalogs and the mistakes in them
C. Leverage ratios
1. Motion ratios
D. Calculating spring rates
E. Shock absorber mechanics
1. Twin tube
2. Mono-tube
F. Reading a shock graph (force/displacement and force/speed)
V. Front su spension
A. Caster
1. What it is and what it does
2. What offsets do
3. Steering Axis Inclination
4. Caster chatter
B. Camber
2. What offsets do
3. Mapping camber change
C. Toe
1. Front end alignment versus four wheel alignment
2. Thrust angle
3. Dog tracking- advantages and disadvantages
D. Travel limiters
E. Bumpsteer
1. How to detect it
2. How to fix it
F. Ackerman Effect
1. Is it good or bad?
2. How can we adjust it?
VI. Rear suspension
A. Leaf springs
1. Locator
a. Instant center
b. Wheel hop and pinion angle
2. Spring function
a. Housing floaters
b. Weight jacking
B. Ladder bars
1. Swing arms
2. Pinion angle
3. Ladder bar length
4. Hardware
5. Tuning with a ladder bar
C. Fourlinks
1. Tubular Fourlinks
a. Equal-length and unequal length
b. Instant centers and maps
c. Roll steer
2. Factory fourlinks
c. Roll steer
3. Tuning with a fourlink
D. Lateral locating devices
1. Panhard bar
2. Wishbone
3. Diagonal link
To Register ...
Call Dave Morgan at (567) 242-9779 or e-mail him at staaytuned@aol.com. The price is $85/person and includes the workbook. There will be a one-hour lunch break (not included in the tuition) and short breaks will be taken every hour. The seminar will run from 9am to 6pm.
Visa, Master Card and American Express accepted
Lunch will provided courtesy of Painless Performance at the Fort Worth seminar on November 22, 2008
SETUP WORKSHOPS:
NEW COURSE OUTLINE:
I. WEIGHT TRANSFER
B. Wheel thrust
C. G-force
A. What it is
B. How to locate it
D. Roll centers
A. Frame rail shift
B. Chassis twist
A. Rod ends
B. Ball joints
C. Leverage ratios
1. Motion ratios
1. Twin tube
2. Mono-tube
A. Caster
2. What offsets do
4. Caster chatter
B. Camber
2. What offsets do
C. Toe
2. Thrust angle
D. Travel limiters
E. Bumpsteer
1. How to detect it
2. How to fix it
F. Ackerman Effect
VI. Rear suspension
A. Leaf springs
1. Locator
a. Instant center
2. Spring function
a. Housing floaters
b. Weight jacking
B. Ladder bars
1. Swing arms
2. Pinion angle
4. Hardware
C. Fourlinks
c. Roll steer
c. Roll steer
1. Panhard bar
2. Wishbone
3. Diagonal link
To Register ...
I was looking into going to one of his seminars last year but didn't have a chance. I think for the price I will make it this year as i'm sure I will learn something new. Also most of the reviews i've read have been very positive.
