welding tubs to quarter panel
7 Second Club
anyone here weld the tubs to the quarter panel? i'd be worried about when the car moves wrinkling the quarters all the time?
any one have experience with this?
We've glued them to the body with urethane adhesive, like you'd use for a windshield. It works great and no distortion from welding (heat makes things move and warp) nor from the tub moving!
if the car is tied in properly it should flex much at all. if you weld them be ready to paint you quarters because if it gets hot enough its going to make the paint pop and distort the metal a little bit anyways. personally i would just glue them in. regardless your going to seam seal the tubs anyways to prevent any water leaking from washing or smoke coming in from burnouts.
forgot to mention to spot weld it in. but yeah be ready for some extra body work and if your going to put a full tub in but without moving the rails or anything be ready to cut the hinge off for the gas cap. with a mini tub you'll be fine.
