Drag Racing Tech
G5X2 Track Results
Old 09-27-2003, 07:43 PM
Ramair346's Avatar
Default G5X2 Track Results
Car is mostly stock weight and had 1/2 tank of gas.
12.407 @ 113mph
2.109 60'
on 275/40/17 nittos
Old 09-27-2003, 08:05 PM
FLA 98TA's Avatar
Default Re: G5X2 Track Results
What other mods?
Old 09-27-2003, 09:43 PM
Administrator
unit213's Avatar
That's not really that good. The G5X2 cam can be a monster. Terrible 60' with Nittos. Sorry for the negative feedback. Just being honest with my opinion.
Old 09-27-2003, 10:54 PM
SNAXS's Avatar
Standard? Automatic? What mods are done to the car? Tuning? What was your time before the cam?
Thanks in advance I have my cam going in teh car real soon and is also a G5x2 camshaft
Old 09-27-2003, 11:06 PM
K I L O's Avatar
Hey wey what will i be runnin with My stall and cam Install.....12's o que pedo
Old 09-28-2003, 01:23 AM
Ramair346's Avatar
Sorry, mods would help.
M6 stock 10 bolt w/ 3.42
edelbrock LTs
true duals
TSP lid
I was heating the nittos up quite a bit and dropped them down to 15psi and still spun thru 1st and got loose into 2nd.
I had another 12.46? @ 116 w/a 2.199
I wasn't disappointed. I know the 60' needs to come down
but do the math and it's easily a high 11 sec. car. I have a set of ET Drags that I've never used, but I couldn't convince myself to bring them without a trailer and a ride home.
Heads and a bottle next year should do the trick.
Old 09-28-2003, 08:00 AM
98TAauto's Avatar
once you get that 60 down she will get alot quicker... 11's more than likely.. or atleast 12.0-1's
good luck
drop some weight out for free HP if you havent already. Lighter car hooks a little better i believe
Old 09-28-2003, 08:21 AM
Mike Hoffpauir's Avatar
You should give more pressure in those nittos a shot. Try 20+ psi.
Old 09-28-2003, 08:30 AM
theblur98ss's Avatar
I ran my nittos around 18ish for best hooking. Heat them up good and I slipped the clutch around 3300. Netted pretty easy 1.9 60's. Play with it and 1.8's aren't too hard.
Old 09-28-2003, 09:10 AM
FLA 98TA's Avatar
good luck
There we go that is waht I was looking for 116mph that sounds more like a G5X-2 it should be fine. get a rear in it then heads. you'll be flying.
Darrell
Old 09-28-2003, 03:23 PM
Ramair346's Avatar
good luck
Darrell
my thoughts exactly
Old 09-28-2003, 05:32 PM
The Juggernaut's Avatar
Hi.
Old 09-28-2003, 07:13 PM
gator's 99TA's Avatar
10.9 versus a 12.4 Elapsed time. see how much setup matters (traction and weight) and how little cam matters in the overall picture? lol. it is true, cant always compare cams on the internet.
Old 09-28-2003, 08:38 PM
11.54 without,10.93 with.
The cam rocks.
Old 09-29-2003, 12:39 AM
01Z, in NO way am i putting down what you have down with your car and lou's cam (i am not a hater), but lets not confuse issues. look at the 60' times and DA differences are massive in the two runs, and ofcourse both are MUCH improved on your runs between cams. there is an easy 2 to 2.5 tenths right there that had nothing to do with the cam.
Old 09-29-2003, 10:29 AM
Fahad's Avatar
edelbrock LTs
true duals
TSP lid
You should more and more quicker on your cam!! are you sure that's is a G5X2?? what's your tuning??
Old 09-29-2003, 10:44 AM
Ramair346's Avatar
edelbrock LTs
true duals
TSP lid
I'm hoping to go to a better prepped track this weekend and cut that 60' down to 1.8.
Old 09-29-2003, 10:55 AM
KGSloan's Avatar
some of you guys arn't very nice. i mean, think about how many variables play into this. 60' times, track prep, DA, car weight, etc. i bet this guy hasn't lightened his very much at all like a lot of the guys that put up the killer times. some people drive their cars everyday, everywhere (like me) and don't want to turn it into a race car with no carpet, insulation, air bags, ac, etc, etc. i mean he has 3.42's in there with a BIG cam. that thing must be a real pain to launch. some 4.11's and he'd probably have 11's right there. just my .02
Old 09-29-2003, 03:47 PM
Ramair346's Avatar
Right on! It's really a pig compared to a lot of the cars on here. I'm waiting to snap the 10 bolt to go to 4.11s and that should help out a ton. Thanks for the insight too!
Old 09-29-2003, 04:15 PM
30th t/a's Avatar
whats your raceweight and what do rpm do launch at? 116mph with 3:42's..man! with that cam 4:11's is gonna turn that thing into a straight jacket maniac!!
Quick Reply: G5X2 Track Results
