Drag Racing Tech
Any other Rear suspension needed?
Old 02-16-2009, 07:08 PM
Formula_Power's Avatar
Default Any other Rear suspension needed?
I am in the process of a 12 bolt install (Along with other things) and I decided to do my rear suspension as well...almost 500 HP with a completely stock rear end and suspension was killing my times. anyways here is what I have so far
1. double adjustable QA1 rear shocks
2. BMR Heavy duty double adjustable LCAs
3. BMR adjustable short style Torque Arm with tunnel mount
4. BMR non-adjustable panhard rod
5. BMR Extreme Anti-roll sway bar
Anything else I need for the rear?
Also what about the front? I am completely stock up there
Old 02-16-2009, 07:10 PM
WhiteLTone's Avatar
only thing i would recommend is maybe LCA reloc. brackets.
Old 02-16-2009, 08:19 PM
ndfrsd6's Avatar
front at least QA1 12 way adjustable ...
Old 02-16-2009, 08:20 PM
C_Rules's Avatar
for the front go with some coil overs, strange or afco.
Old 02-16-2009, 08:59 PM
99bowtieZ's Avatar
Just pull some weight out of the front for better weight transfer Then lets see the light under those front wheels!
Old 02-16-2009, 09:00 PM
Trans Am Jam's Avatar
k member
Old 02-16-2009, 09:01 PM
or if you really want . GO TUBULAR EVERYTHING. supposedly it makes a difference from stamped metal. control arms, reloc. brackets. polyurethane bushings. lol change the boot for the rack-and-pinion . lololol
Old 02-17-2009, 05:23 AM
BlackWS666's Avatar
Aerospace brakes, LPW ultimate 12 cover for the rear. The front is a whole new ballgame, start saving, and looking in the classifieds for lower a-arms, k-member, and QA1 shocks.
For future reference tubular upper a-arms are almost completely worthless, and save 1 pound on both sides. Spend the money elsewhere....
