Competition Engineering Rear Drag Shocks?
I thought I found a couple threads on here about CE rear drag shocks, but I can't find them now. I need new rear shocks and I thought these would be a good option. I just want to double check.
http://www.jegs.com/i/Competition+En.../2700/10002/-1
Thanks,
Nick
Thanks,
Nick
I made a post on this a year or two ago... do a search under my name.
General consensus, great shock, paying a lot more for a better rear shock only seems to have limited advantage especially at the horsepower level the average ls1 guy is running.
Make sure to not cheap on stock front struts and springs, huge gains to be had there. I say get the CE, set them on the 50/50 setting and don't worry about them again. Lots of other suspension work that can be done with the cost difference of QA1, AFCO rears, etc...
Of course if cost is not an issue, hit up one of those companies...
Good to hear!
2 years ago my car dead hooked on 26 inch tires, last year I changed to 28 inch tires and couldn't get the car to hook a bit. Switch back to 26, dead hook. Without a good shock up front you just can't get weight transfer and setting a bigger tire out back will work against that as well.
Needless to say I just picked up a set of QA1 R series fronts for my car this season!
Good to hear!
My stock rear shocks are really worn now though. So much so that the rear wheel well is starting to rub when I have the 28" tires on. I'm pretty sure thats what the problem is at least. I know when I first started running those tires for the first time last season I had no rubbing issues. By the end of the season they started rubbing when I hit bumps or made tight turns. The new rear shocks should help a little.
I have them in the rear of my ta. With a 3.50 gear, and the car running horrible i was getting low 1.7 60 fts on a m6 turbo car with stock ws6 wheels, and 275/40/17 et street radials.
This year i have strange coilovers up front, and a couple other small things. I should be 1.6 60fts, and with a 6 spd i dont think its to bad. When i go auto, i think 1.4's 1.5's should be doable.
For the 90 bucks for both of them, i dont think you can go wrong.
Chris
Chris
N2
Chris
Chris
Seems is different then is. You want the rear suspension to hold its ground so the front can pivot off of it. The "squat" effect you are feeling is not a good thing for racing, although it usually does feel like the car is transferring weight and some guys do end up pulling alright 60' time with this style of a setup.
