Drag Racing Tech
2 quick ?'s
Old 04-26-2009, 11:00 AM
black1999z28's Avatar
Default 2 quick ?'s
First anyone running the MT Drags with out tubes I was told not to use then that the tubes would slow me down.
Second is with my MODS in the sig what gear do you guys think I will trap in the 1/4 with a 26 inch.
Old 04-26-2009, 11:23 AM
bada's Avatar
I run without tubes.
Old 04-26-2009, 11:34 AM
xpndbl3's Avatar
if you're spraying I'd step up to the 28" slick no doubt.
Old 04-26-2009, 12:04 PM
Reboot's Avatar
I run without tubes. Hell, I think most run without them
What valve springs are you running and how high are you spinning the motor?
Old 04-26-2009, 12:23 PM
I have the PRC Spring kit for Texas Speed that is good to 660 lift and as far as how high I going to spin the motor it is still up in the air. Any info would help. Thanks!!
Old 04-26-2009, 03:01 PM
robsquikz28's Avatar
you be fine without tubes...
yes the 28" slick would do you better especially with that 4.10 gear
