Drag Racing Tech
backseat weight reduction
Old 05-03-2009, 03:30 PM
TJ
TJ's Avatar
Default backseat weight reduction
got 4 pounds out of it.
its a quick hack job, but you arent going to see it.
i may go back and cut some more, or drill some holes, not sure.
anyway. give someone some ideas, or get a good laugh out of me.
pound is a pound and i dont like the way my car looks without a rear seat.
Old 05-03-2009, 04:25 PM
98blueSScamaro's Avatar
I was just talking about doing this to make my car look full weight nice job and let me know how much you save on weight
Rob
Old 05-03-2009, 07:24 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
It's a nice idea for those that want to keep the rear seats in the car. I would have done it with a hole saw so there wasn't giant chunks missing. If you hole sawed it would probably have more support.
Old 05-03-2009, 07:46 PM
TJ
TJ's Avatar
its not any less strong than it was.
i cut the big nasty hole in the middle and bottom cause i want to keep the top full, since thats the portion you see looking into the car.
buddy of mine just had a KILLER idea over what i just done.
just get the foam covered and use some HD velcro to hold it in place. noone is going to be back there with a rollbar anyway, so that would be less weight back there alltogether.
its an idea.
i might give it a shot. only downside if it looks like ****, im screwed. the cover will be too small to go back over the frame then.
ill sleep on it.
Old 05-04-2009, 07:04 PM
98silvertacrbn's Avatar
We did this to my bros car but we took the whole plastic piece out and just put the leather back over the foam and Velcro the seat back to the carpet. works great and takes out somewhere around 15lbs seat feels stock also
Old 05-05-2009, 09:37 AM
TJ
TJ's Avatar
was the cover abnormal looking, or did it still hug nice and tight?
Old 05-05-2009, 01:44 PM
looks pretty good i can snap a pic today
Old 05-05-2009, 08:01 PM
here's a picture of what it looks like
Old 05-05-2009, 08:16 PM
TJ
TJ's Avatar
dude, that is awesome.
before i run out and buy the too much or the wrong stuff, what did you use?
i have a small piece here. i need to run out and see, but i think the backrest carpet or the rear hatch carpet should work and only use one side of the velcro?
that would be 8 more pounds out of the car. hahahahaa.
Old 05-06-2009, 11:39 AM
SSIRBY's Avatar
so this is the piece thats inside the back rest?
Old 05-06-2009, 11:57 AM
TJ
TJ's Avatar
yes. this is an lt1 version. the ls1 version is not exactly built like this one.
very similar.
Old 05-06-2009, 01:23 PM
very similar.
They look the same to me. also i used velcro on both sides, and the seat feels stock!
Old 05-06-2009, 01:28 PM
You will need a hooked sewing needle to sew the velcro on with and some nylon thread. We took the rear seat belts out also as long as your passengers are 18 no seatbelts needed if you need seatbelts you can modify your stockers into lap belts thats legal look at me giving sewing lessons
Old 05-06-2009, 06:26 PM
TJ
TJ's Avatar
nobody is getting back there with bars in the way.
Old 05-06-2009, 06:27 PM
TJ
TJ's Avatar
how much velcro is needed? couple of 2" strips of the heavy duty stuff, or do i need a piece spanning the whole seat?
Old 05-06-2009, 07:48 PM
just a couple small pieces will work fine it dont need much
Old 05-06-2009, 10:28 PM
SSIRBY's Avatar
why not just leave them out? i understand "stock appearance" but i just dont see going through with all the trouble just to get 10-15 lbs out.
Old 05-07-2009, 08:01 AM
TJ
TJ's Avatar
i can tell we are apples and oranges.
i dont like to see something unfinished, and i do not want to put 20 pounds in my car for ET reasons.
Quick Reply: backseat weight reduction
