Converter @ track and dyno # worries, help
Ok, over the winter I made some changes to my car. I ported my vic jr intake to match the ports on my heads (quite a bit of material removed). Also, I switched from a 105mm Accufab TB on a sheetmetal elbow to a 2200cfm 4-barrel TB. Last thing is that I added some extensions on to my open headers since that normally picks up some HP.
Now, when I dynoed my car last time, it made 518rwhp and 404ft lbs and when I went last week it made 505rwhp and 424ft lbs, which seems very odd unless I messed with the flow on the intake. Also, while overlaying the graphs, it looks like the converter spiked and I picked up over 100rwhp in the lower rpms in some spots.
Anyway, on to the next item. I went to the track last night and was launching off the brake w/o a 2-step (since I don't have one) and my converter is flashing quite high. Last year the converter would flash to ~4000rpms when on the brake and last night it flashed to ~5500 on the brake (was nice to see some air under the wheels ). Let me mention that this is a ~3600rpm converter so it should be pretty tight. Last year I went 10.601 @ 126.8 w/ 1.45 60ft. and yesterday went 10.505 @ 127.15 w/ 1.380 60ft.
Any thoughts on these issues and suggestions as to what to do. I may just pull the converter out and send it back in to be checked as i'm looking to spray the car soon and with the car coming that high on the converter now, it'll just be a mess on a 250 shot. Here are a couple vids, last year to this year.
Thanks guys and looking forward to some thoughts,
Josh
Pass from last year
Pass from this past Saturday (5/2/09)
Josh
Pass from last year
Regardless of what happens, i'm taking the converter out and sending it back to them for inspection. If it's broken, it needs to be fixed. If it's fine, I need it tightened up considerably before I spray it
Tires are MT Drag 28x10.5W's. Shifting ~7000 and I honestly wasn't paying much attention to what I was going thru the traps at. I'm going to take it out once more before I send the converter in and watch exactly what it stalls at on the brake and then watch my shift extension and what the RPM's are at thru the traps.
