Drag Racing Tech
Recommended Tire Pressure for Nitto Extremes?
Old 05-23-2009, 09:50 PM
TORCHD 02 TA's Avatar
Question Recommended Tire Pressure for Nitto Extremes?
Tomorrow i am going to the track. And my rear tires are basically brand new 315/35 Nitto 555 Extremes (street radial)
What tire pressure should i run them at? I was thinking prolly around 25 or so?
And ideas?
Old 05-23-2009, 10:05 PM
AChotrod's Avatar
Ive had good luck at 18 with a healthy burn out, 25 wont cut it.
Old 05-23-2009, 10:08 PM
Trunion King
bene's Avatar
Go with 25 and work your way down.
I had MT ET streets and I played w/ the psi all the way down to 15 however the best was 16-17 psi.
Old 05-23-2009, 11:15 PM
I am not going to do a burn out. They are not DRs.... Just clean them off a little bit..
Old 05-24-2009, 11:36 AM
Race your car!
JL ws-6's Avatar
I'd start at about 20
Old 05-24-2009, 01:10 PM
mike c.'s Avatar
If you want to hook get new tires. I gained 5 tenths loosing the nittos going to a better tire. I use nittos for streed use only,never at the track.Back in the day when I was running low 12's I bought some old lt1 rims fron junk yard and added better tires M&H Racemaster musclecar drag P305/40/16 for racing. www.intercotire.com gained 1/2 sec over the nitto.
Old 05-24-2009, 03:13 PM
Race your car!
JL ws-6's Avatar
Mike is right. Nitto is a good street tire, but if you want track performance, anything that's bias ply, or the ET radial would be a better bet
Old 05-24-2009, 03:52 PM
cals400ex's Avatar
on the street tires i have the best luck running them at the recommended tire pressure (30 psi or so). on the 555r's i find them to hook better doing a huge burnout and dropping the pressure to around 20 psi.
Old 05-24-2009, 10:40 PM
Today i dropped them down to 30 psi (hot) hooked pretty well. on my TTM 17x10.5 with a 315/35 i got me a 2.0 60'...
I am an M6 on stock 10 bolt. With a DR my rear goes boom
I am thinking i should have gone down to 25 though
Old 05-25-2009, 01:30 PM
robsquikz28's Avatar
drop them down to atleast 18 it will hook way better i had them and hit the gas and go..your rear wont go boom
Old 05-25-2009, 03:21 PM
18 psi even though thery are STREET TIRES and not DRs?????
Quick Reply: Recommended Tire Pressure for Nitto Extremes?
