If I Open The Exh, Will The ECM Go Crazy?
If I open the headers up at the track, will the ECM go crazy and not let the car run right? This ECM stuff is all new to me. I planned to just disconnect the O2 sensors from the Y pipe. It already will not idle worth a crap anyway, and all I am worried about is if it will be ok from the tree to the 1320 mark.
I believe you should be fine. Are you talking about just running open headers?
and as far as the O2's, someone correct me if I'm wrong but I'm pretty sure that at WOT the ECM doesn't even use O2 readings..
