Anyone make their own door panels?
1 Post
I gutted my car and am not digging not having door panels. Anybody have a solution? Anybody make their own light weight door panels?
Man-Crush Warning
edit: If you feel that new door panels are needed, here ya go. http://www.wolferacecraft.com/detail.aspx?ID=784
single ply as in .003" thick? That looks thicker then that. Where did you get it and what are teh demensions? Because, I see the .007" thick (thinnest stuff I found in demensions big enough for a door panel) Laminated Carbon Fiber Sheet 33 MSI Carbon 0° LAYUP was about $80ish in material for one door. and that works out cheaper then the wolfe stuff but I want to be sure that is what you used as I have never worked with CF before...
7 Second Club
we made the carbon fiber... i think its what they call a 4 weave. it has a layer of kevlar behind it...
you have to buy it in a roll and epoxy it and vacuum bag it for several hours.... need to have someone thats done it before... too many things can get screwed up...
Ahh yeah the link I put up was already in "Plate" form so it was already set solid...
I may just go with alum and carpet/felt cover it like I was originally planning...
Man-Crush Warning
That is exactly how I think as well!
I guess that is why I like stock eliminator. Run 10's with a stock lift camshaft, stock heads, intake and TB with no porting on any of that...and 3500 +/- pounds. I guess we could take a torch to everything and run 9's or 8's with the stock internals mentioned above. I don't know. I guess to each is his own. Some people think what I am doing is crazy too.
I don't really know much about fabrics and textiles, but what all goes into carbon fiber body panels, like the CF WS6 hoods you can find? Are those entirely CF? Or is carbon fiber a reinforced fabric stretched over a plastic or other hard surface?
I guess what I'm getting at is, how much of the Trans Am body could be replaced with carbon fiber panels, if these were available and/or they could be made?
7 Second Club
7 Second Club
my buddy makes CF 18 wheeler truck fenders.... toughest fenders around.
