Grinding Calipers.. (Thinking about 15" Setup)
Hey guys,
My car is more of a weekend street warrior then a track car, since I no longer have any nearby tracks. I'm asking in this section, because I figured you would all be knowledgeable in this situation.
I am thinking about getting 15" summit stars. Probably 15x8 rear and 15x4 for the front. I'm having some issues with the caliper situation. This is the only thing making me hesitate from ordering these wheels. I've heard a lot of stories of people cracking their calipers and totaling their cars. I don't know what to use to grind them down, nor where I should grind.
If I were to get spacers (5/16" or 1/2") for the front, would I not have to grind them? Could I use them on the rear too or no?
I'm an idiot when it comes to this, someone please enlighten me.
Thank you everyone.
Thank you everyone.
I dont have skinnies yet so cant speak much about the front but im pretty sure you can just use spacers.
As for the rears it took me about 10 min of grinding each side, to get my 15x8 weld prostars to fit, all that was really needed was cutting that peice in the front center that sticks out off and a little grinding on the corners.
Using spacers will reduce the amount of material you need to remove. Spacers are a very bad idea with these types of wheels as they require the stock acorn lug. You've moving your sheer line increasing stress on the studs. In addition, when you use spacers, you reduce the already small backspace that is being used further reducing fitment and appearance as the wheels will stick out further.
You could consider our drag wheels. They will not only act like you're dropping another ~75lbs from your car over the wheels you're considering but you'll have a direct fit front/rear wheel combination which is built for your OEM brake/caliper/pad combination. They also fits correctly without the hassels of grinding or adding spacers.
You would also be supporting a proudly designed and built USA product.
Don't run China wheels that dont fit correctly. Also summit wheels can only be used in 15x8 which REALLY limits your tire choices. Give Steve at SJM a call, or consider Weld Racings new R/T Street wheels. Both mentioned clear stock brakes with no modifications, and come in the correct 15x10 backspace for a true bolt on correct fitment, and are USA made products. Also both will be EXTREMELY lighter, resulting in faster ETs.
Yep! to the OP, there have been plenty of people to grind their calipers and not have issues. However, this is not a chance you want to take. I have seen first hand the damage a broken caliper can cause on a vehicle. When it breaks on the street, there's no limit to how much carnage it can cause.
I would strongly recommend going with quality wheels designed to fit over your factory calipers such as Bogart, or Billet Specilaties.
http://www.speedinc.com/catagory.cfm...ls%20/%20Tires
we have had great success with the street lites which we are currently adding to our site.
