Drag Racing Tech
trapping 125mph in 1/8
Old 06-17-2009, 02:36 PM
cjg454ss's Avatar
Default trapping 125mph in 1/8
what does it take to do this power wise? with a turbo setup
Old 06-17-2009, 02:45 PM
veee8's Avatar
Kind of a hard question to answer. Weight of car will be deciding factor, I can't be of much help, because I never got my car on the scales, even though I have them right down the road!
But I went like this....
16.5 psi of boost
1.33 60ft
5.63 1/8th
128 mph
8.84
151 with problems, should have been trapping 158+ on that pass, damn detonation!
Car is probably right around 3500 lbs.
Old 06-17-2009, 04:41 PM
Race your car!
JL ws-6's Avatar
To go 125 in the 1/8th with nitrous, I can tell you it's gonna take about 875 to 900 rwhp I think. I went 114 with about 600, to go 125 (which would be an 8 second pass for sure) it would take a good 200 hp more then I am making.
If the turbo setup is building boost out of the gates right I'd think the same power level, this is with a 3350 lb car for referance.
Old 06-18-2009, 02:34 PM
mike c.'s Avatar
I have 520hp n/a and only go 105mph in the 1/8mi. I would need 800 hp atleast.
Old 06-19-2009, 08:26 AM
Shon Herron's Avatar
you going to need a bigger **** Chris.
Old 06-19-2009, 09:00 AM
6 & 8 Second Club
mrdragster1970's Avatar
3200 lbs, car that did not work very good, (60' always higher than others at same ET) broke 125 at 1050 HP.
