Which Race Shifter to buy for 2000 Camaro?
Now that i have my TH-350 swap done with a full RMVB pattern. What is the best shifter to use? Ratchet? Gate? What brand or model should i get. I see some people like that Turbo Action Gate shifter and some have the B&M Pro Ratchet. Our stock shifters have a rear exit cable correct? I am probably going to mount it in my A4 console minus the center section. I like having my arm rest on the center. Thanks
Thanks for the reply FF1101. I am leaning towards that shifter. Do i need any additional parts to go with my reverse pattern? Did you mount it in the console like i've seen on here?
NF Fire Dept here.
NF Fire Dept here.
IMO best shifter money can buy. I have it in my car with a turbo 350 set up.
http://www.precisionperformance.com/home.htm
Coach
Coach
Here is a picture of that shifter with accessories:
I have a hurst with a pistol grip also and it works fine. RMVB with the brake on top. I got use to it right away.
Those posted up there look pretty serious. I bet they do work pretty good. The price is not much more than the normal ones every body uses.
i prefer a gate style way over a ratchet style. It's all in what you like though. The precision shifter is the best you can buy for a 3 speed. If it was a powerglide I could show you a bunch more installed pics. If a NHRA national event is coming by you some time soon, you can go to the manuf. midway and try out a bunch to see what you like.
heres a b&m shifter I put in a fox body mustang I did a bunch of work on. Chopped up the center console and made a new one with a lokar e-brake. The aluminum is either getting painted or covered in upholstry. pretty nice shifter.
