Drag Racing Tech
Front swaybar!!!!!
Old 07-02-2009, 09:38 PM
96formulabird's Avatar
Default Front swaybar!!!!!
ok guys on my good ole lt1 formula. i was thinking bout removing the front sway bar. what are the benifits for drag racing???? i know it shaves some weight, and i hear it transfers the weight a little better to the rear for traction. i still drive my car on the street but im not worried bout taking corners. i mainly go in a straight line. so would it be ok to take it off and drive around and stuff like that???? i think thats all i needed to know. im just curious so any help would be greatly appreciated
Old 07-02-2009, 10:18 PM
Xtremespeed's Avatar
It won't corner as flat as it does now. It'll have a little more body roll. Not enough to be dangerous though. If you're drag racing, yank it off.
Old 07-02-2009, 11:36 PM
Lone Warrior's Avatar
You could just disconnect the end links when you go to the track to see if you feel it is worth the trade off of street driving. Then it is just a matter of reconnecting them if you don't like it or remove it all together if you want.
Old 07-03-2009, 07:49 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I've taken it off, it does roll a little more, dont expect to be banking corners @ 120mph, but as far racing it is weight off the nose and the ability to transfer weight as well makes a huge diff.
Old 07-03-2009, 08:46 AM
MikeG's Avatar
Do a search. This has been discussed 1500 times.
Old 07-03-2009, 09:54 AM
MrElectric03's Avatar
Its alright as long as you try to corner fast but its a must for drag racing
Old 07-03-2009, 10:47 AM
ndfrsd6's Avatar
soooo many threads on this but yes you'll be ok just be more cautious in turns and yes you will notice the difference in how your car launches
Old 07-03-2009, 11:14 AM
black01_WS6's Avatar
I have had mine off for over 3 years now and I drive mine on the street all the time, you just have to get used to it. it takes about 30 pounds off the front nose if I remember correctly. could be more or less, but it is weight off the front which is good for racing.
