Drag Racing Tech
Stuck in mid 11's
Old 07-04-2009, 11:25 PM
Mean87SS's Avatar
Default Stuck in mid 11's
Alright this is my deal, the car goes a very consistant 11.6X @ 117.X all day long...
Its a full weight, cam only car making 406 to the tires... 3500 stall, 3.73 gear on a 275/40R17 ET Street radial
Stock suspention with front sway bar removed, Bolt in UMI TQ arm, and LCAs..
Would adju front anf rear shocks help me out? Maybe a bias ply tire?
[/QUOTE]
Old 07-04-2009, 11:26 PM
Mean87SS's Avatar
My '60 are 1.6X
Old 07-05-2009, 09:23 AM
Race your car!
JL ws-6's Avatar
Adjustable shocks, a set of 15 inch drag wheels to get the rotating mass down some, a bigger stall would probably help too.
Old 07-05-2009, 09:43 AM
Mean87SS's Avatar
The 15's would really make that difference?
I have prostars for the rear but I'm still on a stock rear so don't want to invest the time/money in putting in longer studs.
How big would you go on the stall?
Old 07-05-2009, 09:49 AM
Race your car!
JL ws-6's Avatar
I'd hold off on the rims until you put a rear in the car for the reason you already stated, get the good studs with the new rear when you put it in. Good chance to get the gearing a little better too, 4.10 or 3.89/3.90, somewhere around there would be good.
I'd put a 4400 in the car if track times are you #1 concern, if you still want to drive the car alot, 4000 would probably be a better fit.
Old 07-05-2009, 10:08 AM
Mean87SS's Avatar
Thanks for the input.
Its just an old Yank ST3500 in the stock tranny, so I'll hold off on this combo for a while... or until something brakes
Old 07-05-2009, 11:28 AM
Deerhunter-Z28's Avatar
Just work on the weight if you want to drive it till something breaks.
Old 07-05-2009, 12:07 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I'd do front shocks and more converter. What intake manifold on the car?
Old 07-05-2009, 12:13 PM
AChotrod's Avatar
I agree front shocks and more TC. Taking out weight will always help!
Old 07-05-2009, 10:46 PM
Mean87SS's Avatar
Ported Fast 90 MM on the car right now...
Old 07-05-2009, 11:00 PM
lemons12's Avatar
nitrous.......
lol jk...
i DD a VIG 4k stall.. i would move up to that if you plan on spraying later.. if not, go to a 4400.. the difference DD those is hardly noticeable..
just make sure you get a good converter..
take some weight out if you have not..
those two together should put you 11.3s-11.4s..
Old 07-06-2009, 12:02 AM
Dan
Dan's Avatar
I agree, more stall if you are not spinning
Old 07-06-2009, 12:06 AM
Mean87SS's Avatar
I don't think I'm spinning... but I think I can get more out of my 60' with suspention.
Old 07-06-2009, 12:13 AM
CarsandWomen's Avatar
yank out all that AC stuff, maybe a few hp at the most but between 100 and 200 lbs. Maybe a UnderDrive Pulley if you dont have one
Old 07-06-2009, 12:20 AM
Mean87SS's Avatar
I have a UD pulley.
My A/C is gone, front sway bar is gone, spare tire/jack is gone, lightwieght SS hood,
Old 07-06-2009, 12:36 AM
98blueSScamaro's Avatar
Yank SS4000 and a rear drag bar with a set of front shocks will work killer. And a set of 15's in the rear would be nice.
Old 07-06-2009, 12:58 AM
Mean87SS's Avatar
Would anyone recommend SFC's?
