springs / tire question.
got a set of prostars, 15x10 w/ 6.5 bs. I know I will have to grind......and grind. I also am swapping out my sportlines because these will obviously not fit under there. What spring should I go with and what size dr ?
Internet Mechanic
This should help, the 1st is the link I found and the 2nd is my post about this since it was a street car. At this time I plan on buying a set of Bogarts but will be sometime next year....
https://ls1tech.com/forums/drag-raci...ers-101-a.html
https://ls1tech.com/forums/drag-raci...ns-wanted.html
Stock springs in the back, and no v6 springs are a myth. I have not seen a part number to show it in over 5 years and often when searched at a dealership, it ends up being the same for v8 or v6 cars. Fronts should be a 300 lbs spring or stock again.
