Weight reduction - bumper reinforcement & brackets
Hi,
I'd like to lose some weight from the car, and these two items interest me:
21 Bumper, rear reinforcement and brackets
20 Bumper, front reinforcement and brackets
I read if I remove the suports, the bumpers may sag, but that there is a replacement, that I guess weighs less than stock.
How much weight can I lose replacing the front and rear suports with the lighter weight versions, and where can I get them from?
Thanks for the help,
Paul.
Paul.
Thanks for the heads up ndfrsd6, I'll give them a call. How much weight would I lose with the swap??
Also, I'm considering removing the sound deadening, is it easy to remove (is it all under the floor carpet?), and how much weight would it save? (I want to keep my carpet)
Thanks for the advise...
Race your car!
Wouldnt' be hard to make. couple plates, one bent piece of 1 inch tubing and you'd be good to go.
Just have to add some small round bar with tabs on them to bolt the bottom of the bumper cover in place. I'm surprised that there isn't one available, sounds like something that any good fab guy should be able to do.
When I put the chute on my car I'll make sure the bumper cover is secure, and will get photo's Making plans to get it in over the winter for some changes
Race your car!
Whrn the chute setup goes in, I'll have a round bar in the back that I can use to hold the back of the cover up, and while we're at it, I'll have a couple round bar's come down so I can bolt the mounting points up. It should keep the bumper in shape, even at the speeds I'm planning on seeing. At least I hope :O
Race your car!
Speed inc doesn't make the carpet anymore. Dont' ask me why because it used to sell like crazy, but it's no longer available, unless something changed I don't know about.
Ozite is pretty easy to do, just have to ue a good adhesive under your feet, and take your time and it comes out good.
i just picked up my light weight carpet about 3 months ago it weighed 13lbs great fit for what it is
http://www.speedinc.com/catagory.cfm...r%20/%20Safety
