Out of the hole?
Out of the hole?
Well the time has finally come to take my car to the track on Sunday and put some #'s on it. I have a 2001 Formula and will be running 1/8 mi track. My question is, what would be the best way to leave the line? At idle or should I leave at a higher rpm? Any ideas what the car should run (guesstimate)? Thanks
car weighs 3600lbs. with driver
SLP - cold air and performance air box pkg.
SLP - loudmouth catback exhaust 3"
pacesetter longtube headers
subframe connectors
LS-6 intake and TB
ZO-6 heads (243) and cam pkg. 218/204-.550/.551, 117 lsa
stock A4l60e with stock converter
373 richmond gears
M/T 275x60x15's with M/T skinnies in front
subframe connectors
LS-6 intake and TB
373 richmond gears
I have about 60 passes on mine & I have always got my best 60' leaving at 1000 rpm & stomping it.....high 7s..hard to guess with stock stall.but it should be pretty good.
I know the stock converter is my downfall. But that will be my winter project as my $$$$$ are low right now. Thanks for the info. I'll put my day at the track numbers on Drag race results.
