Will a 28x12.50 15 ET street fit?
Man-Crush Warning
Like the title says, I need to know if a 28 12.50 15 et street will fit my car. Stock length 9", no mini tubs, just a lot of BFH mod. I'm going from a 26x10.50 15 et street to a 28" tire. I can get a really good deal locally on a set of the 28 12.50's. Just need to know if they will fit. Thanks in advance.
I have 28x 13.50 -15 hoosier qtp's fairly well tucked, just the bulge is in line with the upper 1/4 panel. I also have a narrowed rear with a crazy offset so bets to make sure you get your backspacing right first.
I had to beat them in 4 times though, I pummeled it, they rubbed, so on and so fourth..
agree
Yes, with lots and lots of beating, then when you are done, beat some more...
They fit. i had them on my SS runnin all day with very little rub. I had v6 rear springs to raise the *** a little. Consistant 1.50's short times on a 6 speed and spool. i will look for a pic. it may be on my computer at home though.
http://www.jegs.com/i/Mickey+Thompso...3755/10002/-1#
Click more details, it has the specs of the tires.
As mentioned, they fit with a little work. BFH/rolled lips/trimmed bumper cover on the old car with 28x12.50-15 ET Streets, on 15x10x7.5" BS Bogarts with NO spacer on the inside of wheel as provided by Bogart(I had them built w/out the 3/4" spacer).
Wheel tucked real nice, no scrubbing inside or out on the street or at the top end..... ever. Looks real tight(had 3/4" outside tread to body clearance). More toward the inboard side of tread/sidewall), but worked for me. Your results may vary.
Ride height adj. coil overs/adjust PH bar/adj. LCA's are a must IMO.
Man-Crush Warning
Thanks for the responses guys. I picked up the et streets basically brand new for $150 this morning. Tires are being mounted on the bogarts right now. And tonight I'll mount the wheels on the car.
