Drag Racing Tech
Question:QA1 Adjustible Setup for the track?
Old 07-14-2009, 04:47 PM
afterburner82's Avatar
Default Question:QA1 Adjustible Setup for the track?
Anyone on here run the QA1 single adjustibles? If so, what do you set yours to front and rear? I have single adjustibles and a full suspension (save for a tubular K-member and A-arms) with a Moser 9". Also have lowering springs in the rear with LCA relocation brackets. Thanks!
Old 07-19-2009, 07:52 PM
Anyone??? Bueller? Bueller? Thanks!
Old 07-19-2009, 08:11 PM
trigger1's Avatar
Run the rear as stiff as the track will allow. Then make your adjustments up front based on what the car is doing.
Old 07-19-2009, 09:06 PM
DNOBLE1's Avatar
I have QA1 single adjustable in front and QA1 single adjustable coilovers on rear and set just like trigger1 stated. On mine that is usually next to stiffest set on rear and about third from softest on front. Last trip to track got 1.51 60' with 3770 lb. including driver.
Old 07-20-2009, 04:19 AM
Race your car!
JL ws-6's Avatar
settings will depend on car weight and power level, as well as track conditions.
ned more info about what you're putting them on, auto, stick, power, weight, tire?
