Drag Racing Tech
gear, tire, trans combination ?'s
Old 07-14-2009, 10:29 PM
Banging some gears
greyghost4x4's Avatar
Default gear, tire, trans combination ?'s
ok... As of now my car sits w/ stock 6speed, spec 3+, 3:91 12bolt, 28in et street radial... rear is in need of a rebuild so im putting 4:11's in while i have it apart.. my question is... will i have enough gear to run the 1/4mi. if i go with a 3speed down the road? then the combo would sit th350/400, 4:11, 28in tire... motor is completely stock aside from 224/224 563/563 114, spring and push rods, lt's, tune, 150shot
im shifting somewhere around 6300rpms and dont want to have to rev any higher than that if i can keep from it
any and all opinion and knowledge welcome...
Thanks in advance,
Daniel
Old 07-15-2009, 08:44 AM
Bitemark46's Avatar
Whats the tranny ratios of said 3 speed and what converter? Also what is the max rpm?
-Mark
Old 07-15-2009, 09:15 AM
Banging some gears
i dont have a clue about the trans ratio's or converter.. i was hopin that someone could point me in the right direction.. im not going to spin this motor past 6700 it quits making power before then anyway.. and i dont want to be shifting into 5th gear on the in the 1/4 with my 6speed
Old 07-15-2009, 01:39 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Should be fine.
I've run NA and sprayed 150 shot with 4.10's, A3, and 28's shifting at 7000. On motor I was only going thru the traps at like 6300.
Old 07-16-2009, 09:03 AM
Banging some gears
TTT...... anyone else?
