Drag Racing Tech
Narrowed LCA Bracket
Old 07-16-2009, 09:38 AM
tee-boy's Avatar
Default Narrowed LCA Bracket
Anyone ever see an advantage to a narrowed LCA bracket on rear end side? Seems to me you would run into problems with the control arm rubbing front of tire before you have problems with the bracket on the rear.
If you did have a narrowed bracket, who, if anyone, makes a control arm that has a narrowed mounting point on the rear end side to fit into the bracket?
Old 07-16-2009, 11:13 AM
LS1Tech Sponsor
MADMAN's Avatar
We run the narrowed brackets on our rears. I use our offset lcas with a different spacer on the rear.
__________________
www.madmanandcoracing.com
225-343-9029
Old 07-16-2009, 03:47 PM
LS1TECH Sponsor
Steve Burger's Avatar
We have them as an option on all of our housings. It allows us to narrow more than 3" per side.
