project 370ci iron block aimed into 9's any pointers
this is what i have done so far:
iron block 6.0
bored .040 over, nitrous pistons diamond, 11.75:1 compression
stock head gaskets
filled block to keep cylenders from movin around, drilled 1/2 studs
stock stroke crank 6.125 eagle h beam L19 bolts
cam 248/248 comp solid roller 114 lsa
1.7 shaft mount rockers
dart 225 heads hand ported by me
twin disk Ram clutch alum fly
T56 viper internals carbon fiber synchros
moser 9" detroit locker 3.90:1 gear narrowed 2.5 ea side 31 spline axle
custom 6 point cage
mini tubbed have enough room for 13inch wide tires control arm limiting
BMR extreme duty torque arm
fast 90/90 with direct port 300shot
I need to get slicks and wheels for the rear but really don't know what to buy? how to measure how much they grow flex any pointers
iron block 6.0
stock head gaskets
custom 6 point cage
