Am I expecting too much hoping for 10s from my setup?
Well where to start..... Ive got a 1999 SS its 3600lbs race weight it has an iron block 6.0 making 515rwhp@6400rpm and 455ftlbs@4600rpm. It makes over 400ftlbs from 4400rpm-6100rpm. It has a SPEC3i clutch, moser 9" rear with 4.10s. All spohn adjustable rear suspension, with 1" drag bar, all stock front suspension with no sway bar and QA1 struts set at 3, QA1 rear shocks set at 6. The LCAs are on the bottom hole on the relocation brackets and the pinion is -3*. I ran 11.14@124mph with a 1.62 60ft last year with a 28" tall tire and a stock LS6 intake. This year Im running a 26" tall tire to get more effective gear ratio and a FAST92/92 and a fresh tune. I ran 11.11@124mph with a 1.60 60ft tonight after the tune and FAST intake. I dont understand why I cant seem to gain any ET. Where Im stumped is when the car pulled 1.57 60fts the 330ft slows down to 4.7 sec. When I spin what feels like a lot it goes 1.60 60ft and 4.6 in the 330ft. I know you dont want to dead hook. I just cant seem to find a happy medium. I am wondering if I shouldnt step up to a 4.56 gear and go back to my 28" tires. If anyone can give some input Id really appriciate it. If any additional info is needed please ask and I will do my best to provide it. Thanks!
Do you have a dynograph from your tune? If the hp falls off slowly after peaking, then you can run out the rpm's further in final gear without suffering trap speed too much. If it's falling off fast, then you'll want your shift points, and finish line closer to your peak hp. I found this out the hard way with an old "peaky" cam with XER lobes.
What rpm are you at when going through the traps? What rpm do you currently shift at?
Your MPH is very similiar to mine, but you are making more hp than me. Have you done any weight reduction at all?
Mike
Mike
Mike
Mike
Im going through the traps at 6500-6600rpm.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
The rpm band needs to come up a little, or you need to be able to launch it harder. Most low 11 second cars with an efficient driveline will be in the low 1.5 to mid 1.4 on the 60 foot times. That can really add up downtrack.
Derek
Derek
I agree. The best Ive been able to get the car to 60ft is 1.57 on the 26" tires. The best I ever got on the 28" tires was 1.62. It will be interesting to see what happens with steeper gears and the 28s.
Yeah its all about experimentation. There are so many variables youve gotta try everything and see what works best for your application. I will definitely keep everyone updated.
i am in the same boat pretty much. i ran last year @ 3800 lbs in decent air with a set of 27- 10.5-16 et streets and could only muster a 1.63 60', 11.11 et @ 125 with 517 rw. switched over to a 28 -10.5-s et drag and put skinnies on the front and took off ac and ran the same 60' and mph it was higher da' but still thought i would have picked up. i've only got 3:89 gears so that hurt the launch (it would spin alittle then bog,needed to make air pressure adjustments but didn't get in enough passes) but i plan on making a 1/4 pass on spray one of these days so i'll just stick with those gears .
Yeah Ill be moving the LCAs up one hole and see what happens. Ive been all over the place with the tire pressure. Settles around 10-12psi. The DA wed. was 1900-2000ft. We dont get may good DA days here in Indiana.
Yeah I will definitely need to regear. My trans isnt too healthy either but its doing the job right now. Are you still making 418rwhp and running 11.0? What does your car weigh?
Ive got the big Spohn bar. I just guessed at the thinkness. It is the big preloadable/adjustable Spohn bar though. Ive got a spool in the car too so I dont have any one wheel spin issues. Thanks for the info. Thats the things Im looking for. Personal experiences and info like that. I have a set of light weight EDM coated 4.44 gears Im gonna try out. I didnt want to spend a lot of cash on a brand new set of gears just in case they didnt work out too well. So I found the closest thing to 4.56s I could find in a used set of nascar gears.
Still its the trap speed, I should be a touch higher then 125, im thinking 126-7 easy, as I had to let off completely between shifts, shift, and come back on with the power.....Not good for racing When I was 200 lbs heavier, and on 26's with 4.11 gears it went 11.13 @ 124, +73 da, so it should pick up alot....
I used to 60' 1.57's on 26's, dropped to 1.50-53 by re gearing and running 28's.
And yes, still 418 rwhp ...
Its A lightweight, 3105
http://www.youtube.com/watch?v=VN2RI...e=channel_page
