Help with bad tire rub.
I dont know if this should be here or in suspension tech because it kinda goes hand and hand. Anyway what could be causing my pass side tire to move forward and hit the wheel well. This was done on a very small part throttle hit on the street after installing the new tires just to see if everything was good. The tires are 275/60/15 M/T's. I have had the same size tire on the car before and nothing like this ever ha pend. I did just put on BMR nonadjustable tubular LCA's to get rid of the stock ones.
If you look at the pics you can see the black rubber on the front of the wheel well.
