275 Guys...a little advise please
My car has been running extremely consistent all year(11.1-11.2) and the end of the season is coming around and i REALLY wanted to get a 10.99 pass under my belt before this winters tear down. I have been running MT 28-10.5 slicks all season and have never had worse than a 1.55 60ft, with a best of 1.44. I decided to drop about 50 pounds of weight and switch to a MT 275/60 hopeing for a little more in the top end speed. Took it to the track a few weeks ago and blew the 275s off. I didnt adjust anything but the weight and the tires.
I was running QA1 shocks 0 front, 6 rear. And the tires were at 18psi cold with a 3-4 second roll out burnout with minimal, almost no smoke. The track was hooking well, and the weather was nice also. The weight changes were removal of pass seat and harness, door bars, formula hatch, door bars.
So what changes should i try for this weekends test and tune?
7 Second Club
Slicks will tolerate too much RPM better than drag radials, back down the RPM. They need to dead hook. You need to find the max RPM you can leave without spinning them. I think we've got our leave down to 50rpms. If we add 50 it spins, if we take it out it will 1.2 to the 60'.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
as mentioned, try lowering the rpm. radials are less forgiving than slicks, plus the sidewalls don't flex as much as slicks. Every car is different, but you may have to work at it a little. Try different pressures as well, but make sure each pressure you try is a legitimate pass (in the groove, minimal variables between runs, etc). If not, make 2 at each pressure before changing stuff.
My Nova going from 28 x 10.5 M/T stiff sidewall slicks at 15 psi to 275/60/15 M/T radials at 18 psi picks up about .05-.07 and 3/4 mph.
Derek
Derek
Derek
Derek
LS1Tech Co-Founder
Madman told me the start with the rear shocks on the stiff side. I had them at 7/7 and the fronts at 2/2, and then I took out 2 psi air in the rears, and put the fronts to 1/1 and went 1.35 on my 325's.
lower your tire pressure. i turned up my 2 step to 4k with 18psi and they spun like crazy. put it down to 16psi and they dead hook and lift the tires.
btw i have 275/40r17 so i dont have much of a side wall at all.
The tires will work, dont fret, and when they do you will have a new best 60ft. Happens everytime I see someone put these tires on.
I run 17psi in my 275/60s, my front QA1's are set at 6 if I remember right. Im assuming you have LCA brackets, etc. the full works on your suspension? I was one of the lucky ones, slapped DRs on and they hooked from the start...1.3x 60s.
I run my rear qa1 on 6 front suspension stock and 20 psi in the 275/60 1.55s on motor and best of 1.36 on the gas . I have a ptc 3600 its a little tight and stall to 2500 hooks everytime n/a . On the nitrous its a little more tricky . I hated my DRs until I started doing a real burnout and playing with psi do that and they will hook .
She went 11.03 @ 120.68 with a 1.422 60ft. The tires were set at 17/16.5 psi, and was launching at 3000 off footbrake, and the burnout was exactly how i did my slicks. Definitely felt like she was grabbing better. So I cut .02 of the 60, and .07 off the quarter going to drag radials from slicks. MPH was exactly the same. Weather was near the same as the last time I went as well.
