what flexplate for a 6.0/th350 combo?
mabey ill have better luck in here as opposed to the auto trans section since its more drag specific....
i have a 6.0, th350 and a vig converter from my lt1 (standard sbc style). Do i need to buy a specific flexplate for a lsx and use the spacer for the TC or can i buy a standard sbc flexplate? Or will it not bolt up? I seen them for sale for lsx cars but dont know how compatible everything is for the different combos one person can have.
Ok, i dont know exactly, but i do know a little. As far your motor it would depend on the year. I guess some of the earlier 6.0's had a little longer crank. If you had one of these you could use a normal sbc tc. But if you have a later year, i believe after 2003, then it is the same length as ls1 ect.
I believe you need a converter set up for a ls1, so you dont have to use a spacer, and the Tci Flexplate part TCI399753.
I am not 100%, but i just got a ptc converter for a ls1, a th400, and that flexplate, and will be putting it all together soon.
Maybe give brian @ speed inc a call, or Dean @ drc.(who speed inc uses for th400's)
Good luck, Chris
Good luck, Chris
for ***** i took a pic of the crank. I noticed that the threads start about a 1/2 back. Is this the years i dont need a spacer because the crank is so much thicker right there or are all lsx cranks like that?? I dont have a lsx to compare too...
Phil, im gonna buy a TCI flexplate. Iv seen a few break and im not gonna skimp out here, just need to know what one i need.
madman does custom dipsticks. I have one in my garage. its a really nice looking piece, but have yet to install it.
http://www.madmanandcoracing.com/sho...aspx?itemid=13
