Drag Racing Tech
Midplate and off the shelf headers?
Old 08-31-2009, 08:23 PM
csjta2's Avatar
Default Midplate and off the shelf headers?
Is it possible? I looked at putting a midplate in my car, but after looking at the right side header, I don't see it happening unless you get custom set of headers made
Anyone done this with off the shelf headers?
Old 09-01-2009, 01:48 AM
chvypwr31's Avatar
i would also like to know this,(lt1 headers)
Old 09-01-2009, 03:32 AM
LSmonster's Avatar
I have a Madman mid-plate and kooks headers.
Old 09-01-2009, 06:03 AM
Fireball's Avatar
can also trim the midplate as needed
Old 09-01-2009, 07:39 AM
mad_steve's Avatar
x2, so long as you don't get too carried away with the saw
Old 09-01-2009, 08:45 AM
LS1TECH Sponsor
Steve Burger's Avatar
We have a mid plate setup that works with almost any header.
There are pics in here and in the gallery section of our site under my car.
Old 09-01-2009, 10:05 AM
ATwelveSec02Z28's Avatar
Mine took some work to get to fit, this is a comp engineering plate, had to cut off the passenger side tab and weld on a new tab that met the frame rail higher to allow header clearance.
Old 09-01-2009, 02:33 PM
veee8's Avatar
Can you just use spacers on the converter when using a midplate? I know it is tight right now getting to some of the bellhousing bolts, how do you do it with a midplate added? Where is the desired chassis attaching mount point?
Old 09-01-2009, 02:39 PM
Fireball's Avatar
or you have the converter built for the midplate thickness...
as for the bolts...very long extensions with a universal joint...definately not fun to install/remove...
Old 09-01-2009, 04:44 PM
csjta2's Avatar
I have QTP 1 7/8 headers, there is no way that I can get a midpalte to work with these headers that I can come up with, unless I do the 1 5/8 bar from framerail to framerail.
LSmonster, do you have any pics of your Kooks and midplate setup?
Old 09-01-2009, 05:22 PM
LSmonster's Avatar
Sure. But remember, I don't have anything hanging off to the sides of my block. I trimmed all that off and hung my mid plate from the top. In my "opinion," hanging it from the top is the best way to do it. Take a look at my "Rookie VS. the 25.5" thread and you'll see how I did it.
Old 09-01-2009, 05:24 PM
csjta2's Avatar
Thanks LSmonster
I think that's the only way this will work, atleast with the current headers I have
Quick Reply: Midplate and off the shelf headers?
