video inside. help my take off please!!!
This is the first time I have ever drag raced and my stupid self kept burning out in the water instead of rolling past the water, then burning out. Anyhow my car is getting anywhere from 375 to 395rwhp through M6 w/ maybe 150lbs removed.
I am not using nitrous yet, but everything else in my sig is correct. I was able to pull 1.72 60ft times with a horribly warmed up ET Street. Do you think I could get 1.5's if I burn out properly? Here is the video, it doesn't show my burnout though. But does it not look like I am slipping way to much on the launch?
Also I have single adjustable coilovers all around. How loose should the strange front coilovers be? and I'm assuming the QA1 rear coilovers should be pretty stiff? Thanks for any help. Here is the video....(Times will look funny since I slowed down at the 1/8th and it was clocking us at the 1/4)
http://www.youtube.com/watch?v=UqfyIwDw-u0
The front you want to lift up and transfer the weight to the rear. The only reason you would want to stiffen the front up/hold the front end down some is if you were having bad wheelstand issues. You want the rear as soft as possible without hurting your 60'. There is a such thing as too much bite. You waste energy planting the tires instead of moving the car forward.
