Drag Racing Tech
From 28x10.5/15S ET Drag to 325-50/16 ET Street Radial = Mistake?
Old 09-17-2009, 01:44 PM
CARTEK Racing
WS6TransAm01's Avatar
Default From 28x10.5/15S ET Drag to 325-50/16 ET Street Radial = Mistake?
The car has gone consistant 1.41-1.43 with an ET Drag with stiff sidewall, I am thinking about switching to a M/T DR this fall in roughly the same size...
The ET Street Radial is slighty smaller, 87" rollout compared to 88" roll out making it 27.7" instead of 28" tall, but that will only kill off 2mph, at rev limiter, a margine that I believe I have. I know they will not grow much ompared to the slick, but with the currect gearing and limiter I do not think I will get to there either way.. maybe I will be surprised who knows...
I know these tires have gone VERY fast with automatic cars, but I have not seen them go quick with a M6... Can they? Have they? I don't want to conduct a $450 experiment w/o at least some knowledge behind it...
Thanks guys...
Old 09-17-2009, 02:06 PM
5.3LJimmy's Avatar
My car would not hook on them, so I switched to the ET drag. Same sizes you have listed for both tires. I'm not saying it can't hook, but the slick is easier to hook than the radial with a M6.
Old 09-17-2009, 02:30 PM
CARTEK Racing
that has been my line of thinking all along...
I run a ~ 28" DR on the street, maybe Ill just get the 295-45-17 for street use...
Old 09-17-2009, 04:52 PM
jmm98LS1's Avatar
I couldn't make 325/50/15 MT radials work AT ALL on my car. They are now my street tires and I run 28x12.50 et streets at the track. MT radials were designed to work on footbrake auto cars. They CAN work on transbrake or clutch cars, but it's tricky and your suspension has to be spot on. Bias plys are much more forgiving to marginal suspensions and poo-level track prep.
Old 09-17-2009, 09:34 PM
CARTEK Racing
point taken... looks like ill order another set of 28x10.5 15S's
Old 09-18-2009, 04:32 AM
Nitroused383's Avatar
I have been reading great things about the M&H tires. There is a guy on these boards cutting 1.4 60' with an m6. I think he is running the cheater slick. Also studderin is running their radial tires with an m6, he cuts 1.55's I believe.
https://ls1tech.com/forums/8114003-post17.html
http://www.mandhtires.com/store.php?...on=show_detail
Old 09-18-2009, 04:52 AM
jmill96Z's Avatar
Honestly, it just takes alot of testing to make DR's work. I's a whole different world when it comes to setting the car up. If you have the patience, they really do work incredible. The times in my sig are on radials--325/50 15's.
Old 09-18-2009, 06:42 AM
blk00ss's Avatar
Jmill, your an auto. The OP is a M6, two completely different worlds here. I think it's possible to cut good 60's with radials. My best to date is a 1.65 on 325/50/15 mickeys. With a slipping clutch. I think with a new clutch I can get down into the 1.5 range. But slicks are a lot easier, and less finicky to me. Best 60 on a 28" slick is a 1.50 flat.
Old 09-18-2009, 08:08 AM
tektrans's Avatar
I ran the 325's when I had my 408. They worked very well, off the footbrake, off the transbrake forget it and with an M6 like yours forget it.
I'd love to see your car with a set of 30" Hoosiers 30x9 radial slicks and more gear.
If the 28's have been working for you, and they have, just stick with that.
Old 09-18-2009, 08:52 AM
jmill96Z's Avatar
So how are all the heavy hitters getting it done on radials? Every one of them has a brake. It just takes time to sort the car out. Alot of people don't have that type of patience.
Old 09-18-2009, 08:57 AM
studderin's Avatar
hey alex, its not close to your 60's I'm making alot less power, and get 1.53s 1.55s (6500 2step) on the same size 28 S ETdrags. And been racing on mt DR and been impressed, is alot easier then having to change tires at the track.
28" 275/16 M&H on stock wheels all around. 5700-6000 2step, best is a 1.600 and I'm locked in the 6.10 1.625 range unless the track sucks.
Old 09-18-2009, 09:18 AM
NSSANE02's Avatar
It's not impossible to hook a dr with a 6-speed. When I had 275-60's I could dump the clutch at 6k and dead hook, had a best 60' of 1.60. Granted I have a lot less power than you but I also got it to hook on a 125 shot to a 1.5 60'. Out of curiosity, why are you thinking about switching?
Old 09-18-2009, 09:29 AM
CARTEK Racing
THe only reason I considered switching is in the hope that the tire will hook the same, with less work when I get to the track lol... I can change both tires in only a few minutes with the cordless impact gun, but it would be fun to just drive, race, drive home.
Also, the Radial might net me some more MPH.
Mark,
Yeah I would love the 30" Radial slick, LOL But my fender wells wont! lol
4.88 with a 30" tire is the same as 4.56 with a 28" tire lol
MMMMMMMM Gearing.... Yum!
Old 09-18-2009, 09:30 AM
tektrans's Avatar
Mostly if not all are FI set ups which are easier on the tires at the hit as opposed to a N/A or nitrous set up and most of those guys are on a 30" radial, not a 28" (27"xx).
Old 09-18-2009, 09:33 AM
tektrans's Avatar
Mark,
Well your 28" slick at 140mph will grow to nearly 2" on the big end so since the 30" (they really measure 29.5") don't grow at all they should fit with no issues.
Old 09-18-2009, 09:34 AM
tektrans's Avatar
Alex just dynoed over 520rwhp.
Old 09-18-2009, 09:43 AM
jmill96Z's Avatar
Might want to look at what the 275 guys are doing. ATV, RPM, Smith, Cyrus, Bowman.
Old 09-18-2009, 10:07 AM
tektrans's Avatar
Didn't know those guys were on a 275. Good point. Still think it will be hard for a 6 speed to make it work but you do have a point.
Old 09-18-2009, 10:15 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
A3 Formy I ran a bunch of different tires, went 1.35 2nd pass with 325's with coaching from Madman. I think with a stick car you'd have more work to figure it out. If you use a 2 step might not be as hard since you would launch consistently.
But dr's are unforgiving where slicks will work with a variety of shock settings and tire psi. With DR's are need to find the perfect combination of front/rear shock settings etc., to make it all work.
Old 09-18-2009, 11:41 AM
CARTEK Racing
No idea what Mark is talking about here...
I think you have me confused with another Trans Am H/C car from CARTEK...
Quick Reply: From 28x10.5/15S ET Drag to 325-50/16 ET Street Radial = Mistake?
