Drag Racing Tech
firewall plate after dash and hvac removal?
Old 09-20-2009, 02:44 PM
nickp's Avatar
Default firewall plate after dash and hvac removal?
i need to cover the big hole in the firewall after removing all the heater stuff. i have a piece of aluminum sheet thats prolly about .030 thick. could i use this? or would it be too thin. thanks
Old 09-20-2009, 03:18 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I used some 18 gauge sheetmetal
Old 09-20-2009, 03:52 PM
97BlackLT1TA's Avatar
That is what I used as well.
Old 09-20-2009, 04:08 PM
studderin's Avatar
thats sounds really thin,
theres a min thickness for alum and steel, check NHRA/IHRA stuff... I think its like .38 steel .50 alum??? But some bead rolls go a LONG way in a flat pannel like that.
And I know the halo style cage rules change if you have a large hole or changed the firewall alot, ther some size specs, But you have to run a dash bar if so.
Old 09-20-2009, 04:51 PM
nickp's Avatar
Thumbs up
thanks for the info. i was kinda wondering about the rules on the firewall. i've got got an s&w 8 point, so i dont have a halo or a dash bar. thanks
Old 09-20-2009, 04:59 PM
studderin's Avatar
ya not 100% sure. I know there some ya/no rule on the dash bar neeeded for legal on a rule I heard the HAVC cover plate affects it they way you can interprete that. Not many know/inforce it I believe, its more for moving the motor set back and sectioning the firewall/ holes for airbox/charge pipes I think?
Old 09-21-2009, 08:47 AM
LS1TECH Sponsor
Steve Burger's Avatar
We make a delete plate for that.
